Hi built a RMCK Hydrolift 1100 and powered it with two TP 4060 1600 KV 4200 WATTS Max , two Turnegy 180 ESC , two 6 cells 4000 MAH Nanoteck lipos, 45-90 C . Two 82 mm stingers 3/16 flex drive shafts and two counter rotating Octura 447. I have run the boat about 10 times and have constantly got 110 km/h after getting CG correct as well as stinger angles. BUT I have now blown two of these motors.The magnets have come away from the stator or armature and jammed as a result have blown the esc.
TP REPLACED THE FIRST MOTOR BUT ITS NOW HAPPENED AGAIN. My rpm is way less than their stated 50 000 rpm.The last motor I blew has jammed so badly that I cant get it apart even hitting with a light hammer. Its totally solid. All the binding holding the magnets in place has come away. The bearings seem to still be OK.
Why is this happening! Can someone please help.
Thanking you
Graeme
Thanking you
Graeme
