Genesis 3/16" Drive shaft upgrade help
  • CliffordMVAS
    • Dec 2012
    • 1
    New to RC Boating, bought the Genesis and of course upgrading like crazy. Need help with 3/16" shaft install. My parts listed below.
    Motor : Leopard 4082 1600Kv 2Y
    ESC: Seaking 180
    Battery(s): HYPERION G3 EX 5000 MAH 3S 11.1V 45C/90C LIPOLY PACK
    Smoked the stock prop in seconds.
    So I ordered the 3/16" shaft kit from below.
    How do I go about installing it? Any help would be much appreciated. Thanks.
    Cliff
  • iamandrew
    • 577
    Jesus Christ....... OUCH $$$$$$$$$$$$$$
    youll have to remove / cut out the existing stuffing tube to fit the new one, also bend it to shape.
    To be honest, if your doing a 3/16 setup, you want to use 1/4 brass tubing and no teflon liner.
    I have found that if you use a teflon liner and larger than 1/4 tube, you usually cannot insert the brass tube into most 3/16 struts.
    realistically though
    collet = $10
    Flex shaft = $20
    Brass tube = $3
    Speedmaster 3/16 brass "thingy" $10 is all you need
