Finding cog
  • GatorsFan
    • Aug 2012
    • 34
    Finding cog
    This may or may not be a stupid question but im having troubles finding the answer to it. What is the best way to go about finding the cog for a deep vee like the delta force pirate 35?
  • Old Sloppy
    Harry from Atlanta
    • Jul 2007
    • 200
    I can not answer for your hull exactly.
    In general, 30% as a starting point.
    a little less on calm water, a little higher on rough water.
    Harry
    60" Expresscraft SuperCat
    (2) 2028 Castle motors 64.7 mph
    10s3p with x450/3 props
    15,000 mah 40c cells,
    • martin
      • 2887
      Yep as stated 30% is a good starting point on a deep v mono, in the case of a 35" hull start around 10.5" in from the transom.
      • GatorsFan
        • Aug 2012
        • 34
        Thanks for the answers i have read about the percent i was asking how to go about checking it
        • bob_t
          • Sep 2012
          • 160
          Take something thin (1/4" thick wood, or a couple layers of thick cardboard glued together) about 1" tall and cut a Vee in it. Don't make it too thick, it needs to be narrow, closer to a knife edge is better, but 1/4 inch-ish is fine. Set the boat (with batteries in it) in the Vee and see if the boats tilts toward the transom or bow. Move the Vee block forward or aft until the boat more or less "balances", not wanting to drop on the transom or drop towards the bow. The location of Vee block is your COG. Its easier to do on a cat since the bottom is flat ... all that you need is a piece of dowel rod that spans the beam width of the cat and do the same thing as above ... move it fwd or aft until the boat balances. Hope that helps.
          • GatorsFan
            • Aug 2012
            • 34
            Thanks thst helps alot i have a cat also i figured it out just wasnt sure how to go about it on a v hull
            • lenny
              • Sep 2010
              • 4294
              Boat stand works good to if on the edge of a table.
              ? ONLY IF THEY WORK
              • martin
                • 2887
                On a mono measure the length of the hull & take the % that you want, on a cat hull measure from the rear ride pad to the front of the hull & take the % you want. Always work from the rear ride pad & not o/a length of the hull on a cat.
                • Old Sloppy
                  Harry from Atlanta
                  • Jul 2007
                  • 200
                  on my mono's I lift the hull with a finger on each side,
                  grab it up high, near the top of the freeboard.
                  I then make a pencil mark where my fingers were ballancing the hull so then I mesure the mark with a ruller.
                  Harry
