Bec ?????????
  • MAMBA2200
    I need a scooby snack
    • Jul 2012
    • 1202
    Bec ?????????
    I have burned up 3 castle creations 10a bec lately and cannot figure out why 2 have melted down and one just quit. This has happened on 2 different boats both running same esc 120a seaking they ran for a minute and quit. Now im not over amping running both on 4s i have checked and rechecked wiring but cannot find a explanation for this. Now i have one that is working fine and im pulling way more amps on that rig than any other it just dont make sense and was wondering if anyone else has had these issues. I have sent them back to castle and they sent me new replacements and installed them and the same thing happenedso i ask can someone give me any advise on this problem thanks in advance.
    Im Only Responsible For What I Say Not For What You Understand
  • Doug Smock
    Moderator
    • 5272
    According to this the SK 120 has a BEC. Have you disabled it?
    http://www.offshoreelectrics.com/pro...er-seaking-120
    D.
    MODEL BOAT RACER
    IMPBA President
    IMPBA 19887L CD
    NAMBA 1169
    • MAMBA2200
      • Jul 2012
      • 1202
      yes i did remove the red wire and when they quit i can plug it back in and the boats run again i know i dont really need them but any help with amp draw im gonna use it lol
      • properchopper
        • 6968
        I've had the same experience with the CC BEC. Three died, two shot full battery voltage to the Rx ; took out two rx's in flames and one servo as well. Guess what I won't ever use again ?
        • Basstronics
          • Jun 2008
          • 2345
          The 120s I hear have a really robust bec. Maybe try without any bec?
          • MAMBA2200
            • Jul 2012
            • 1202
            i hear ya on that anything you can recommend?
            • Doug Smock
              Moderator
              • 5272
              Interesting, I'm not sure why the SK's and the Castles wouldn't be playing nice.
              If you continue to have problems I'd run a RX pack with that combo or just use the SK bec.
              "but any help with amp draw im gonna use it lol"
              D.
              MODEL BOAT RACER
              IMPBA President
              IMPBA 19887L CD
              NAMBA 1169
              • MAMBA2200
                • Jul 2012
                • 1202
                when i first got them i used my eagle tree to check amp draw and with the bec it was lower than it was without the bec
                • oscarel
                  • Dec 2009
                  • 2127
                  What servo are you using? Have the BEC's gotten wet?
                  • MAMBA2200
                    • Jul 2012
                    • 1202
                    no they have never been wet and im using futaba and savox servo's
                    • Doug Smock
                      Moderator
                      • 5272
                      The servo is going to require the same power regardless of which BEC it comes from. What was the difference in load? What voltage do you have the Castle BEC set to?
                      MODEL BOAT RACER
                      IMPBA President
                      IMPBA 19887L CD
                      NAMBA 1169
                      • MAMBA2200
                        • Jul 2012
                        • 1202
                        I saw about 4-7 amp lower and i have them set to 5v because my eagle tree says not to use anything higher than 5.9 volts when using it
                        • oscarel
                          • Dec 2009
                          • 2127
                          I see you have another thread in the Mystic forum. Are the BEC's only frying in the Mystic? Have you burned one without the eagle tree hooked up? Are you using the same receiver?
                          • MAMBA2200
                            • Jul 2012
                            • 1202
                            nope on my motley crew also yes i have fried without eagle tree and each boat has its own mr3000
                            • oscarel
                              • Dec 2009
                              • 2127
                              One more thing to keep in mind, this is from Castle:
                              Peak: 10 amps
                              C
                              ontinuous:
                              <12 volts input = 7 amps*
                              <24 volts input = 5 amps*
                              *Ratings are determined with a 5mph airflow on the BEC. Servo connectors are not rated for current in excess of 5 amps. Users are encouraged to replace the connectors if more than 5 amp currents are anticipated.
