Dulling my boats bottoms up help needed
  • Ocean Racer
    • Sep 2007
    • 502
    #31
    Originally posted by Xzessperated
    My comments were just in fun. That is why I put smilies after them. I hope you did not take me the wrong way.
    No i didnt take it badly just given you a heads up thats all. Its bad enough they want to get rid of fishing so I try not to give them reasons to help them with that.
    Failure is the First step to SUCCESS
    • Xzessperated
      • Apr 2008
      • 3060
      #32
      I love my fishing too.
      Several boats in various stages of destruction
      • Ocean Racer
        • Sep 2007
        • 502
        #33
        From what im reading it all depends on preference. But so far the pengeulum is swinging toward a ruff or scuffed hull. But it also sounds that just like some boats like certain setups they also like/dont like being scuffed. SweetZ28 I think what happened is the scuffing made a grove/groves or chanels that allowed water and air to pass through. This lessened the sucktion on the hull.
        • Ocean Racer
          • Sep 2007
          • 502
          #34
          Good to know im not the only one here
          • scooterP
            • Jul 2009
            • 237
            #35
            This will always be a point of discussion. When I was around some of the folks that machines Nascar and Indy intakes, the concensus was that you would not leave an intake perfectly smooth, but leave it a little rough. The reasoning was that as air and fuel flowed and mixed that it would stick and fill in the roughness on the intake surfaces and allow a super smooth path for the air/fuel mixture to travel. Resulted in better flow and a little more hp. I've seen this proven on a flow bench. It was also theorized that the rough surface caused the fuel air mixture to mix better which resulted in better hp. I know we are talking about water flow on the boat hull and not intakes on cars, but it seems like the same principal.
            • ozzie-crawl
              • Sep 2008
              • 2865
              #36
              there has been discussions for years as well about porting, polish or leave rough for the same reasons you mentioned.
              i sand the bottom of my hulls but one thing that intrigues me is when most of my boats are running at wot there is bugger all touching the water.
              • Diesel6401
                Memento Vivere
                • 4204
                #37
                So my question in listening to all this is would it make sense to wax the sponsons of say a ul-1? Since wax or a smooth hull tends to ride wet or stick more to the water do you think to would help reduce the deadly sponson dance a ul gets at WOT?!? Just a question and I may be complely in left field on this, but this just popped in my head.
                - Diesel's Youtube
                - Diesel's Fleet
                • tharmer
                  • 342
                  #38
                  I think Sweet has the right of it. Shiny hulls create suction, dull hulls provide water/water boundry layer. It's one reason why sharks (and olympic swimmers) swim so fast. Doesn't make by itself a huge difference but in combination with a bunch of other things, helps.
                  Does this mean we shouldn't polish our rudders and fins?
                  -terry
                    #39
                    The reason for the "dance" is the geometry of the sponsons combined with speeds in excess of the design limit. I doubt very much that wax/no wax would make much difference.
                    • Cat-Boi
                      • 240
                      #40
                      400 grit. Sand all ride pads. definitely helps.
                      Sandy Squitieri
                      www.graupner-usa.com
