HV setup question?
  • forescott
    Hopelessly Addicted to RC
    • 2686
    HV setup question?
    I am starting a build with a 56 inch mono. Running a castle 2028/ice 200 combo on 10s max. I want to start with a 457 prop. FE calc. says low 60's on 10s which is great. My question is if I want to run in a smaller pond at say 40-50mph at wide open throttle, will the motor/esc pull the same amps running less cells? Say 8s for 50mph or even 6s for 40mph? I know its better to run at wide open throttle, but what happens to the amp draw when the cell count is dropped??
  • keithbradley
    • 3663
    The load will be less on 8s and current draw will go down as well, unless there is another pnenomenon occurring (boat rides to wet on 8s, etc.).
    www.keithbradleyboats.com
    • jcald2000
      • May 2008
      • 774
      The reverse will happen from keiths advise when you try to slow down too much.
