X-power question???
  • Stealth Assassin
    • 610
    This hull Is a very mild set up with a 10xl, 4s (#2 2s packs In series), x-power 100a with a x438 on solinger mono HW and all 5mm bullets.
    The shaft Is smooth as silk and everything Is wired correctly I checked this many times. The water leak Is the only thing that makes sense. It did not burn down bad but, It did smoke with a glitch. There Is a short somewhere In the esc. I pluged It back In after the glitch and It smoked.
    • Stealth Assassin
      • 610
      Originally posted by kburrows
      i think a smaller tube still would'nt have given enough cooling to that ESC.
      The esc has smaller water Inlets so, that limits the water just the same as a smaller line adapter.
      • G Doggett
        • 446
        Sorry to hear of your disaster with the hose popping off.
        The X-Power ESCs water cooling pipes are 3.5mm OD.
        I found that medium size silicon tube from my LHS fitted fine as it has an ID of 1/8 inch ( 3mm ).
        The water flow is fine on my Twin Jolly with this set up.
        Graham.
