Rough water medium mono hull?
  • kevinpratt823
    • Aug 2012
    • 1361
    I have gone back and forth deciding on a few hulls, any input or help deciding would be great. I'd like something that ose stocks, as I am local and can pick i up, also Steve is good to us.
    I'd like something that can handle some rough water, in the 33"-35" range preferably, to run on either 4s or possibly 6s(1600kv), with a 2000kv 4082 motor/seaking 180, and go over 50mph. Looking at the following and going back and forth in my head.......
    DF33
    DF35
    DF Cyber Storm33
    DF Pirate 35
    AeroMarine Titan 33
    Does one do better in rough water? Pros vs cons?
    My private off road rc track
  • Jason4636
    • Jun 2012
    • 654
    I like the looks of the DF35 the best. I was going to build a DF 45" sniper, but now I'm going bigger. There's alot of build on here about the DF35. Have fun
    • Basstronics
      • Jun 2008
      • 2345
      Is the Cyber Storm not a deep vee?
      If so that might be your better bet. I have a 32" Pursuit and the V isnt that deep... Just my observation here. 33" is stilla healthy sized boat really.
      • kevinpratt823
        • Aug 2012
        • 1361
        Here lies my dilemma, basically all 4 of the DF hulls I listed have the same description:
        These light weight fiberglass boats are built for Fast Electric Rc Boat Racing. Designed as a deep vee with a small rear pad makes this boat both handle well and achieve a very good top speed. Hull and deck are joined leaving only a very small pencil width seam, similar to the European designed hulls.
        The Titan has a similar description as well, but it does ave a bit of carbon layed in.
        Not sure of the actual differences in hull design......
        I would think a deeper vee would handle rougher water, no?????
        • kevinpratt823
          • Aug 2012
          • 1361
          I am thinking about a Sniper 45 as well, along with this one.
          • Jason4636
            • Jun 2012
            • 654
            The sniper would be a good hull for a proteus on 8s
            • dana
              Banned
              • Mar 2010
              • 3573
              Well the bigger boats will obviously handle more chop better.
              • keithbradley
                • 3663
                Kevin,
                Are you looking for something that's already built, or something to build yourself?
                I have a DF 35 that I am getting ready to put in the swap shop. It's RTR (with your lipos and radio) with a HV setup (5682 + 20/100 FC ESC). I've only ran it a few times on 8s, but it could be ran on 9s as well.
                If you're looking to build your own, I would still reccomend that hull. I ran it in lake Huron in about 1-2ft waves and had a blast!
                www.keithbradleyboats.com
                • T.S.Davis
                  • 6220
                  8s at Sharp Park! You are the man Keith.
                  We once ran a AM Cylone on that pond with 5 geared Aveox motors in it on 12 cells each. Still wasn't as fast as an 8s boat. Ran a 56" Appachy up onto land there too. Those were the days.
                  Noisy person
                  • BHChieftain
                    Fast Electric Addict
                    • 1969
                    If money is no object then check out the toysport triton. Built like a tank and also available with a flood chamber. My son runs one with a 4s2p setup.
                    Chief
                      • 8011
                      The OP needs to focus on his goals. He wants a hull between 33"-35" but folks are recommending the 45" Sniper. The cost of the latter will be close to twice that of the smaller hulls. The Sniper will handle more chop simply due to its size. Will he be racing? What is "rough water"? To some it's 2" chop, to others is 8"-10" waves.
                      In the original size range the Titan 40 is probably a slightly better rough water hull. It has higher freeboard and I think a slightly deeper vee. We have four in our club and they run great in mixed water conditions up to the low 50s, but like any hull they can be driven too fast for conditions. The DFs are slightly faster in smoother water. If you want to go 60+ mph in really "rough" water, then the 45" Sniper is the best choice.
                      • lenny
                        • Sep 2010
                        • 4294
                        Hi,
                        Where will you be running this boat at, Pond, lake, Ocean, ?
                        And how far of a drive is it to where you will be running it ?
                        And carrying stuff all the time to the waters edge ?
                        I agree with Jay on the Titan 40 or 45" Sniper if you want bigger and have the cash for it's setup,
                        The Pirate 35" is a very cool hull to and built very will.
                        [QUOTE=kevinpratt823;468942]I have gone back and forth deciding on a few hulls, any input or help deciding would be great. I'd like something that ose stocks, as I am local and can pick i up, also Steve is good to us.
                        DF33
                        DF35
                        DF Cyber Storm33
                        DF Pirate 35
                        AeroMarine Titan 33
                        Does one do better in rough water? Pros vs cons?[/QUOTE
                        ? ONLY IF THEY WORK
                        • kevinpratt823
                          • Aug 2012
                          • 1361
                          OK, I'll try to clarify......
                          I am already thinking of building a Sniper 45 as a completely seperate project this winter, not instead of a 33-35 mono, this thread is for the 33-35 mono.
                          I will be running in a pond, one of which is large and windy, so hoping to handle wind and say 4-6" chop with some speed. I looked into the Toysport, seemed like a lower quality build at first glance, besides, I did a quick search and didn't see them readily available.
                          I listed a Titan 33, Fluid, have not seen a 40, but for the larger boat as I said I'll prob do a Sniper 45 as an additional build for really rough stuff.
                          Keith, isn't that motor a bit big for that hull? Looks sweet though, how do you get 9s?, (3)3s in series?
                          I'm looking to utilize some of the things I already have, here's a quick rundown:
                          2 pairs 6s
                          3 pairs 3s
                          2 pairs 4s(one pair is only 3850 mah/25c, really only good for paralell, not 8s)
                          also have a 2000kv leo 4082 and seaking 180 on the shelf, as well as rx and servos
                          Part of my interest in handling rough water has to do with winter. I still want to be able to run when the water's not frozen, but I do NOT want to worry about retrieval as much.
                          I will definitely be getting my feet wet with building over the winter, but I thought about getting the cyberstorm that bully has in fs forum and be done with it, just not too clear on the damage to the hull............
                          • keithbradley
                            • 3663
                            2 pairs 6s
                            3 pairs 3s
                            Yeah, the 5682 is a bit on the large side, but it runs well and stays nice and cool...perhaps a bit more torque roll than a smaller motor but fine for a sport boat.
                            I run 4s + 5s to get 9s, but you can do it any way you want (6+3, 3+3+3, etc).
                            I think that cyberstorm is probably a pretty good deal. Larrysdrifter is a pretty straight forward guy...send him a PM about the boat and I'm sure he will fully explain. I'm guessing it just has some knicks in the gel.
                            • kevinpratt823
                              • Aug 2012
                              • 1361
                              Already been in contact about the Cyberstorm, waiting to hear back again. If I don't take that one, I think I'm going to build with a Cyberstorm hull. Research(propperchopper's thread) seems to show that it has more deadrise and handles chop a bit better.
                              I have been leary of running different cell counts in series Keith, would you say that matching them is critical all around, or just Mah ratings, or nothing at all, just don't run too long?
