Brushless outboard motor?
  • Andris Golts
    • Jan 2011
    • 504
    Hi all . When operating b/l outboards and being exposed to spraying and dunking them in water. Would this reduce their operational life span as opposed to an inboard instalation ? All my boating is in fresh water and after a day of boating i give a shot of compressed air through the motor holes and a drop of oil on each bearing. Are there any web forums specific to electric outboards.? Regards Andris Golts.
  • Ryanrc
    • Nov 2012
    • 10
    Hi Andris, sorry I can't answer your question as I am wondering about the exact same thing. Quick question, are you running a bl outboard on a mono hull? If so, what is the correct height to mount the motor? Regards, Ryan
    • stifflkd
      • 17
      You may want to separate the motor and spray it down with Corrosion X or Boeshield T9. At a minimum keep the bearings oiled.
      • Doby
        KANADA RULES!
        • 7280
        Just spray some WD-40 in the motor at the end of the day, power it up and give it some throttle (slow speed only) to spread it around inside and all will be well!
        I have been running the same UL-1 motor on mine for 3 years with no issues. Its been upside down, sprayed etc more times than I care to admit.
        Grand River Marine Modellers
        • Andris Golts
          • Jan 2011
          • 504
          Thank you all for the great information i have corrosion x on my work bench i will give it a spray . Regards Andris Golts.
          • topfuel443
            • Nov 2011
            • 82
            I run all FE outboards, and use WD40 and Corrosion X liberally. Never had an issue.
