I have had fun with the UL-1, and I'm looking to continue in that direction with another boat. What are some good opions for building/buying an FE Hydro, say 30"plus, that will get up over 60mph at least? I will have 4 new 6s/5000mah/65c lipos to work with, planning to use those.
30"+ Hydros, options?
My private off road rc track
https://www.youtube.com/watch?v=XC3H...yaNZNA&index=8Tags: None -
Do you mean 1/8? 1/18 is small.........
Where do I find his kits?
Edit: found them. I may not have the experience or patience for a kit like that yet. The most I want to get into at this point as far as "building" is starting with a bare hull.My private off road rc track
https://www.youtube.com/watch?v=XC3H...yaNZNA&index=8Comment
If you intend to run 6s, you will probably want a boat over 34" long. You will have ample power and the larger hulls handle th epower and rough water much better than the smaller hulls. The 6S boats in my club vary from 36 - 39" long and run high-60s/low 70s in race water. The ML wood hull best suited for 6S is the 39" long GP400.
Phil Thomas Hydros
国产肉体XXXX裸体137大胆,无码人妻精品一区二区三区东京热,亚洲精品久久无码AV片动漫网站,老师黑色双开真丝旗袍恩施MBA,亚洲人成色777777在线观看,日韩精品无码一区二区中文字幕,无套熟女AV呻吟在线观看,狠狠做深爱婷婷久久综合一区Comment
Phil Thomas Hydros
http://www.metimeliverc.com/HobbySho...6/Default.aspxMy private off road rc track
For 6s power with the Seaking 180 esc I would use Neu 1527 1y (1250kv). My Whiplash 40 Q sport hydro is very fast with that motor and Octura x455 (average amps pulled 140 with a spike of 193). I think the Neu 1527 1.5d (1500kv) would be faster, but may be too much for your seaking 180...not sure?Attached FilesLast edited by detox; 11-06-2012, 06:52 PM.Comment
Kevin,
A few bits to think about. To begin with : on 6S the 4082 2000KV is spinning 44,400 rpm, and the 4074 1800KV is spinning 39,960. Way too much unless you want to make 3 second runs and bring it in. Also, 6S packs are going to be a tight if not impossible fit in 30" hulls.
The PT, as has been recommended is a great boat, but if you check out their builds and runs, they are build-intensive and require carefull and somewhat constant fiddling with adjustments ( I just spent three days with a racer setting records with his, and his feeler guages and lead ballasts were in constant use.)
OTOH (and yes, I have a vested interest) the FE30 is ridiculously easy to rig, needs little or no fiddling, runs FAST and is built like a brick sh*thouse.
68.6 mph on 4S1P with a Neu15151Y (think Leo 4074), T-180 and M445. I race mine with 4S2P 4000's and a M545 and it rocks your socks
Here's the new Turbine cowl it comes with
DSC03687.JPG2008 NAMBA P-Mono & P-Offshore Nat'l 2-Lap Record Holder; '15 P-Cat, P-Ltd Cat 2-Lap
'11 NAMBA [P-Ltd] : Mono, Offshore, OPC, Sport Hydro; '06 LSO, '12,'13,'14 P Ltd Cat /MonoComment
The Phil Thomas SS45 is probably the easiest 'glass hull to get on the water, and they run awesome. They do not need feeler gauges and six months to set up.There are four in my club, all with 1527/1Y motors. The 1527/1.5D has proven too much for a sport hydro, it is better suited to a rigger. I run an Aeromarine Shadow, but it required some mods to run well. The AC Pro40 is a great hull too, but is seldom converted to FE - the hatch requires some work to seal up. The Whiplash 40 is also a great hull if you want to build from wood. There are several hull options and considering how "popular" this size hull is, we are lucky to have what we do.
