need some help
  • eclipse
    • Oct 2007
    • 365
    need some help
    im looking to make my super hawaii brushless.im in the middle of the transformation.i found a motor to power the boat i just need an esc to go along with it .the problem is i dont have a lot of money to spend on it .here is a link to the motor http://www.offshoreelectrics.com/pro...prod=fei-540XL anyone with helping info to find a esc for this please post up. thank you
    ----------eclipse
  • jeffm912
    • Apr 2008
    • 153
    It all depends on which wind motor you are getting but Steve sells a 100 amp opto controller right here for under $80. That is your best bet unless you want some foreign job that takes weeks to get it in your hands. Also Steve has great customer service. It's called the x-power esc, there is both a 70 and 100. Hope this helps.
    Jeff
    • eclipse
      • Oct 2007
      • 365
      thank you i will look at it and its around the price i want also great help.btw what does the wind on a motor mean?
      • eclipse
        • Oct 2007
        • 365
        your talkin about this one rite? http://www.offshoreelectrics.com/pro...od=xpo-blb100a
        ----eclipse
        • jeffm912
          • Apr 2008
          • 153
          Winds determine the kv's of the motor. Depending on what type of boat you are using the motor for and batteries you plan to use. You'll see if you look into the motors more that you'd probably want something like the 10xl or more for that size of a boat on 4s lipo or 12 nimh. Give me some details and I'm sure I can help you out.
          Jeff
          • eclipse
            • Oct 2007
            • 365
            lol yea i know what kvs are and you mean winds as in turns wright.and 10x1 means 10 turn single modified right?i was thinking of this ---540 6XL 2,779 RPM / Volt
            i believe thats the fastest one right?
            thanks------eclipse
            • Rex R
              • 992
              it also has the potential to blaze right through your wallet. what sort of voltage were you planning on running?
              • eclipse
                • Oct 2007
                • 365
                either 2 of these http://www.offshoreelectrics.com/pro...d=ep4500-7cell
                or maybe just one what does anyone preffer?
                -----eclipse
                • Rex R
                  • 992
                  hmmm 36", yes? big boat. my personal feeling is that a 540 9xl on 12cells(14v) would work better.
                  • eclipse
                    • Oct 2007
                    • 365
                    i want speed though
                    • eclipse
                      • Oct 2007
                      • 365
                      i want it to compete with those nitros lol any links would be great
                      • calcagno45
                        • Mar 2008
                        • 1006
                        rethink you setup maybe.
                        maybe a 12xl on 5-6s with a hydra 240.
                        • jeffm912
                          • Apr 2008
                          • 153
                          A 6xl motor is hot for any setup, with it you would have to use such a small prop that your boat wouldn't move at all. Try a 10xl and a 42-45 prop on the back with that 100amp esc I mentioned earlier. Also just use 12 cells or a 4s lipo. I'm sure some others will chime in, hell you could even use the supervee motor with those same props to get it to move out.
                          Jeff
                          • Steven Vaccaro
                            • 8721
                            The guys are pointing you in the correct direction. 6xl will burn up a 240mp esc in that size boat. If you really want to compete with some nitro guys, I would suggest a new hull with the correct hardware. Otherwise you will be dropping a bunch of cash into something thats not made to run 40-50mph.
                            • calcagno45
                              • Mar 2008
                              • 1006
                              Also, that 100amp Xpower should only be used in applications running 70-80% of the rating, or it will
