neu 1521 1.5d timing on t180 please
  • driftah
    • 760
    just curious what the recommended timing is on a 1860kv 1521 neu with a t180 esc,I will be running it in a 31 inch mono on 4s2p and a x447/2 prop?
    first neu motor for me....
  • racerr73
    • Oct 2007
    • 133
    Timing - 3.75
    Should be able to run a detounged 447/3 with that set up especially since its running 2p.
    Trev
    • properchopper
      • 6968
      3.75 works fine. Bolt on a 450/3 and hang on (motor won't break a sweat, watch the T-180 temps)
      • carlcisneros
        • Jan 2010
        • 1218
        driftah
        go with a 445 first run it for a minute then check temps
        then go with a 447 and do the same thing
        then IF EVERYTHING checks out, THEN try a 450.
          My Titan 40 with that motor and 4S2P pulls over 200 amps continuous with that x450 prop, be careful! It is awfully fast though....
          • driftah
            • 760
            weird the orig owner told me closer to ten deg. hmmmmm
            • dana
              Banned
              • Mar 2010
              • 3573
              It's a d wind. 3.75
              • Jesse J
                scale FE racer
                • Aug 2008
                • 7116
                then again, I use 0 timing and a detongued 452... dang that's fast.. and warm when she gets in, but then are you racing to keep you equipment cold or to win?
                "Look good doin' it"
                See the fleet
                  I sent an e-mail to Steve Neu about four years ago asking about timing, and here is what he said:
                  D winds : 0 - 4.75
                  Y winds : 9.0 to a max of 15.0
                  • driftah
                    • 760
                    sounds good but old owner is saying ten yikes,I will go with the 0 to 5 area lol
                    • CHIEFY_44
                      • Nov 2010
                      • 254
                      i run this motor in a 34" mono 4s2p t-180 and run a 450 3 blade no problem
                      Socal Fe member, miss gieco castle 1515 1y t-180, blackjack29 stock,insane FE30 p sport castle 1515 1y t-180, insane FE30 p spec ul-1 motor t-120, insane 34"mono neu 1521 1.5d t-180
