Any of you guys know anything about seaducer hulls?
Seaducer hulls
Tags: None
Seen them run in "A mono" as a .21 nitro setup (crazy fast little buggers) and I was flat impressed that is a sweet hull. Id like to try one myself as an FE setup some day. Im not a real exspericed person in boats yet but seems like a great hull design and alot of guys run them with good reviews. I think that hull design hold several records even. -
They can be hard to set up but when you get it right they run awesome. They are also tight on space in the inside and hard to tape up. That's why you don't see too many FE ones running. Doug Smock has taken a bunch of IMPBA straight away records with them. All that being said, I had a bad experience with Seaducer so I can't say I would recommend one.Mike Chirillo
www.capitolrcmodelboats.com
I just picked one up for a $100 it's 28" long 9" wide almost 3.5" tallSlow and steady isn't my paceComment
Yea I was looking at making it a fe boat but making a top for it might be difficult..... I'm thinking nitro might be the way to go on this one the guy included some type of tuned pipe with it as we'll. I'm excited about starting this build.Slow and steady isn't my paceComment
You've got the shorter of the two versions. Jerry makes a 33" and a 29". They are a bit tricky to set-up, but can be awesome when done right. I have a 21, 45 and 101 in nitro and a 33" version was my first FE. Mine ran very wet and I sold it prematurely without trying to fix it first. Some pics attached.
Tyler
DSCN5989.jpgDSCN5994.jpgDSCN5995.jpgDSCN6610.jpgDSCN6625.jpgTyler Garrard
NAMBA 639/IMPBA 20525
T-Hydro @ 142.94mph former WRComment
Ok kool, thanks ccr. How are they tricky to set up? When you say running wet is that where the front of the boat want to nose in the water?Slow and steady isn't my paceComment
Tyler
[ATTACH=CONFIG]87662[/ATTACH][ATTACH=CONFIG]87663[/ATTACH][ATTACH=CONFIG]87664[/ATTACH][ATTACH=CONFIG]87665[/ATTACH][ATTACH=CONFIG]87666[/ATTACH]Do It Like You Mean It .....or Don't BotherComment
Use the Seaducer hardware or Speedmaster. These boats are very particular with hardware so I would not recommend a stinger or longer offset rudder.Tyler Garrard
Hey Chris,
You want the 20 mono rudder and the SDS strut. http://www.seaducerboats.com/hardware.htm
The set up instructions are on the site.
Good luck.
Doug
Elizabethcity SAWs 022.jpgMODEL BOAT RACER
IMPBA President
IMPBA 19887L CD
NAMBA 1169Comment
