epoxy dried-any ideas?
  • bozo586
    • Aug 2009
    • 344
    picked up a used boat with dried epoxy on the hull bottom. air dam was removed-leaving the epoxy. is there a way to remove the epoxy without-screwing up the jellcoat?
  • Basstronics
    • Jun 2008
    • 2345
    Heatgun or hairdryer. Use minimum amount of heat and keep working at it then some heat until it breaks loose.
    Works like a charm.
    • bozo586
      • Aug 2009
      • 344
      basstronics--thanks--will do this tomorrow afternoon--results to follow after my dentist appointment.
      • drwayne
        • May 2008
        • 2981
        phenol based paint stripper.. paint onto epoxy, will soften.
        stop the reaction with phosphoric acid. or will eat the whole boat !
        USE GLOVES
        • bozo586
          • Aug 2009
          • 344
          bad day fri dentist fix didn't work--tooth broke again! bottom of boat got hot,and soft-stopped trying to get the epoxy off--i will run it like it is.
          • Basstronics
            • Jun 2008
            • 2345
            Yup it will do that. Its a plastic type resin after all. You want to direct the heat best you can to the affected area. It will take a little muscle to get it loose but grab it with pliers and work it back and forth and it will go.
            • bozo586
              • Aug 2009
              • 344
              not enough there to grab with anything. only about 1/16 high or less in spots,about 1/2" wide--better i leave it alone! does not hurt anything!
              • longballlumber
                • 3132
                Hey John,
                Why not just sand it down. Sometime that's the only way to effectively get rid of cured epoxy without damaging the surrounding areas.
                Later,
                Mike Ball
