Anybody out there like Shoe Goo as much as I do? I use it on lots of stuff and it seems to hold better than epoxy or JB Weld in a lot of applications. Motor mounts stay on fiberglass better, stuffing tube braces, I even glue servos and have yet to have one come loose, even on 40" outriggers. But if you have to remove it I use a stiff putty knife to get under it and it comes up pretty easily. Any thoughts?
Shoe Goo/Household Goop
Tags: None
I like that it is semi permanent and stays a bit flexible. I use it to seal the strut on my 1/10 shovel (strut is mounted on inside and exits thru the bottom of the hull), seal holes, and secure components to the bottom of the hull-- I like to know I can remove it to change the layout and balance if I want.
Chief -
I have found a very similar product called E6000 sold at Micheals and Hobby Lobby even Walmart and it is a little cheaper than SHOO GOO it works great only thing I have found taht you can glue the plastic fuel takns together and they actually hold and to get them apart you have to work at it. Some really great adhesive.Comment
