I dont really know what Im looking at with my Castle Creations data logging. The graph is much easier to read than the file i saved...just lots of numbers taken every few seconds. Anyways, i got the avg and max readings noted, tell me if Im safe. The set up is a leopard 5698 910kv, Castle Creations Hydra Ice2 200HV, 2x4s 5000mah Turnigy 40-50c lipos for 8s total running 5.5mm bullets, and a x452 prop. Water was very choppy, ran for about 7min total. 1 min into running the collet on the motor came loose from the cable...turned off my trans and full throttle kicked in for a few seconds. Turned it back on and it stopped. Forgot to adjust my failsafe I think. Tightened the cable collet, then back off and running.
Volt: avg 37.3 max 45.2
Ripple: avg .9 max 4.34
Current: avg 6.9 max 130.2
Amp hours: avg .38 max 1.96
Watts: avg 221 max 3951
Temp: avg 73 max 115
RPM: avg 13331 max 116004?? I double check, but that cant be correct.
Throttle in: avg 1.570 max 1.989
Power Out: avg 13.9 max 100.
So...am i good?? Est speed was 50ish.
