And just when I thought my tinkering days were over......
Been thinking of ways to get the heat out of the kitchen and came up with a concept, so feedback is more than welcome.
Idea is to have a one-way valve inlet/exit allowing heat to escape while protecting the interior from flooding. So I did a test with a mesh called Flow-Rite. It's very fine and resists water to a certain degree, yet air will pass through with a little force.
In the test, I used 15oz of weight from water and inverted the container with the Flow-Rite attached. Water would not come out if it was in a level to semi level position whereby covering the mesh, however if I were to hold the cup sideways, the weight of the water would begin to pass through. (more testing needed)
So then I thought of a one-way valve system (front and back) that when the EDF would run, the intake would open through vacuum as well as the exhaust.
A float switch and relay would break the connection if the boat were to invert, thus automatically closing the one-way valves and shutting down the fan.
A modified cowl could contain all the necessary parts. Small Lipo could be set into the hull.
I may be wrong by thinking a three channel transmitter/receiver would be used to activate the fan setup, but a better idea might be a small circuit that activates the system when the boat motor itself is running. A timer chip could be set to have the cooling system run for a few seconds longer after the boat is not operated (upright).
Looks good on paper, just wonder if there are any other thoughts on this?
