I M GOING TO 180 HV HYDRA WITH 6 LIPOS SPLIT AT 5000M 20C 10XL MOTOR AND ANY SUGGESTIONS FOR PROP OR FOR THE SET UP ON ELAM THANKS UL DRIVER ICE IM WORKING ON THIS PROJECT RIGHT NOW WHEN FINISHED ALL POST VIDEO IF BOAT SURVIVES POWER
Taylor is correct, the 10XL is really too much. A club member now runs a 12XL in his 1/10th scale hydro on 6S and it flys. When he ran a 9XL he could only run three laps before thermalling....
I have the Proboat 1/12 Llumar Hull and the real estate is very tight in front of the motor, unless you breach the sides and place your LiPo horizontally into the sponson area.
I am considering on running either an 8L-3072kv with 3S/4500/30C or an 8XL-2084kv with 4S1P/4500/30C using (2) 2S packs. Getting the correct COG are a challenge on these boats. Good Luck!
I've tried that setup on my Mean Machine running 6S1P/4500/30C. A 12XL-1390kv motor will run ideal on 6S Lipo. It went 53mph on a m545 prop. It really depends on the prop you use. I would prop up slowly starting with a x440 - x442 - x445 - x642 and check temps after 1 minute of the initial run with each prop. According to my formula, here are some conservative speeds you might achieve with each prop:
