opinions
  • highflyerbill
    • Jul 2011
    • 152
    opinions
    I'm looking to spring for a 21FE outrigger . I know the JAE21FE is out there and highly regarded ? Are there any other's . Would like pre built if possible ? Suggestions for motor and running gear for 4s lipo power.
  • RaceMechaniX
    • Sep 2007
    • 2821
    I'll make the shamless plug here for the Raptor Riggers: Brian Buass designed and built the Raptor Rigger around P-Spec power systems using a single 4S pack. You can swap out the P-spec motor for a P motor such as a Castle 1415 1Y which fits nicely in its place. Even with a P-Spec system the combo runs in the low 60's with a very conservative prop. Use a more aggresive prop and higher speeds are easily attained. The hulls construction is vacuum bagged fiberglass with the option of full carbon. It uses standard Speedmaster hardware on the transom and comes with a turnfin and bracket.
    Very nice clean design that runs exceptionally well. In my humble opinion, it takes a lot more work to get the same performance from a JAE.
    Here are a couple pics of Raptor Riggers:
    Tyler Garrard
    NAMBA 639/IMPBA 20525
    T-Hydro @ 142.94mph former WR
    • martin
      • 2887
      Are the Raptors available as a kit or prebuilt or just mouldings, if so is their a contact for them to get prices etc. Thanks Martin.
      • RaceMechaniX
        • Sep 2007
        • 2821
        Martin, It would be best to discuss options with Brian. I will PM you his contact info.
        Tyler
        Tyler Garrard
        • highflyerbill
          • Jul 2011
          • 152
          Tyler would you PM me the info also thanks
          • RaceMechaniX
            • Sep 2007
            • 2821
            PM sent.
            Tyler
            Tyler Garrard
            • RaceMechaniX
              • Sep 2007
              • 2821
              Here are some more pics, I grabbed these off an old thread.
              Tyler Garrard
              • RaceMechaniX
                • Sep 2007
                • 2821
                Here are some pics of my P Rigger and Mark Grim's in action.
                Tyler Garrard
                • SirBudman32
                  • Aug 2011
                  • 625
                  Tyler, Could you P.M. the info as well. I would like to build one over the winter, Thanks.
                  Modified Jae21, Stock Jae21, Cheetah, Ul-1, Shock Wave 26 V2 (Rescue Boat).
                  • RaceMechaniX
                    • Sep 2007
                    • 2821
                    I guess the more pics I post, the more boats to sell.....
                    Here is the rigger in the hands of Brian setting the first sub 20 second FE 2-lap record: http://www.youtube.com/watch?v=QguZfASDE8I&feature=plcp
                    Here is the same hull with a P-Spec motor instead of P: http://www.youtube.com/watch?v=3hfKewhkvLg&feature=plcp
                    More pics from the Namba FE nats:
                    Brian's P Rigger 2.jpgBrian's P Rigger 3.jpgBrian's P Rigger.jpgJohn's P-Spec Rigger 2.jpgJohn's P-Spec Rigger.jpg
                    Tyler Garrard
                    • highflyerbill
                      • Jul 2011
                      • 152
                      Are the rear sponsons an option
                      • RaceMechaniX
                        • Sep 2007
                        • 2821
                        I would ask Brian, but I believe yes.
                        TG
                        Tyler Garrard
                        • Mike Caruso
                          • May 2012
                          • 940
                          Very nice Rigger Hmmmmm
                          Do It Like You Mean It .....or Don't Bother
                            Regardless, they are a vital part of the hull's design. It will not run like the videos show without the rear sponsons. They don't slow the boat down for SAW runs either.
                            • martin
                              • 2887
                              Does the 2 rear sponsons have less drag as i understand they both ride just off the water, compared with the single ski that the JAE use which i take it runs on the water all the time. Martin.
