Warning: Trying to access array offset on value of type null in .../vb/bbcode/url.php on line 114 Replacement boat for Spartan drivetrain????? - Offshore Electrics Forums
  • traeside
    • Aug 2012
    • 190
    Okay so I am having trouble getting the chine walk out of my Spartan so I was thinking about putting the stock stuff back in and running it on 5S. so then what would be a good fast stable hull to put my 4092 1480KV and Seaking 180 in?
    Has anyone ran one of these?
  • ENCORE MAN
    • Jan 2010
    • 891
    Ric0 31
    Rico 31, it would run well with this power setup.
    Here are some pics. LMK if you are interested. BG
    $(KGrHqJHJEsE-js(zPJ)BPpmU1tvHQ~~60_12.jpg$(KGrHqZHJCwE-lTJk,ZrBPpmUvbV9!~~60_12.jpg$(KGrHqFHJBkE-fbpSHq8BPpmVLLqoQ~~60_12.jpg$(KGrHqNHJEQE-Q,8uln6BPpmUo4SSQ~~60_12.jpg
    • traeside
      • Aug 2012
      • 190
      I was thinking a Cat but always looking. how fast have you had her? is there some transom damage it is hard to see?
      • ENCORE MAN
        • Jan 2010
        • 891
        H & m intruder s
        There is no damage on this nearly new boat. You are seeing camera flash shadowing and picture #4 verifies this. With present motor on 6s, the boat is capable of the low 60's.
        Perhaps you would prefer an H & M Intruder S
        • traeside
          • Aug 2012
          • 190
          [ATTACH=CONFIG]85327[/ATTACH][ATTACH=CONFIG]85325[/ATTACH][ATTACH=CONFIG]85326[/ATTACH]
          nice looking what is it? what are you looking to get for it?
          • traeside
            • Aug 2012
            • 190
            Is there a for sale section on OSE?
            • traeside
              • Aug 2012
              • 190
              if i get a mean machine 18 is that the same hull as here?
              • Make-a-Wake
                FE Rules!
                • 5557
                http://www.offshoreelectrics.com/pro...rod=df-delta33
                • traeside
                  • Aug 2012
                  • 190
                  i was looking at that hull do you think i could use the hardware off the Spartan?
                  • Make-a-Wake
                    FE Rules!
                    • 5557
                    Dont see why not.
                    • traeside
                      • Aug 2012
                      • 190
                      ok so i put the batteries back in the back turned the LVC off and well.......
                      • traeside
                        • Aug 2012
                        • 190
                        So the ESC was filled with water i never hit any controls but it stuttered just as i got the batteries to pull them. everything is in rice bags now. what do you think my chances are that it is okay?
                        • IRON-PAWW
                          • Oct 2011
                          • 314
                          Water inside any esc's electronics isn't good. If you get on it *straight* away with the likes of WD40 you might save them. Make sure they're *dry* before you go anywhere near using them again. Is that the Seaking 180? You need to seal those up pretty well before installation in a boat in my opinion. They have a plastic case around their electronics board that *isn't* waterproof at all - you *need* to waterproof it or run it in a watertight box. If the water was in it for any length of time my bet is it's finished. But dry it out for a good length of time and try again............. Carefully...... Hope it works for you.
                          PERTH AUSTRALIA
                          • traeside
                            • Aug 2012
                            • 190
                            Yes it is the SK180 and i had it covered it with liquid tape but i guess i missed a spot. i see where one guy fills the whole case with liquid tape. it was in there about an hour by the time we retrieved it and got it home and apart. i died it with air and it has been in a bag of rice and desiccant for 2 days so far. will Steve fix it if i send it in?
                            • IRON-PAWW
                              • Oct 2011
                              • 314
                              Although Steve is a man of many talents, fixing a fried esc is a tall order. You may be ok. Going from memory here, but I seem to remember you can take the bottom cover off the Seaking 180's. If you did that and are getting it dried out then you're doing all you can do. Just test it and see how it goes. But.... I got water inside a SK 180 not long ago and it was curtains - even after I'd dried it out and gave it the wd40 treatment. Once you get water inside electronics components there's not a lot you can do. But - try it and just see if it lives. Put it in the sun to get some heat into the unit to hopefully evaporate the moisture from inside all those components. Worth a try....
                              PERTH AUSTRALIA
