Need to clean inside of hull after esc melt down?
  • Andris Golts
    • Jan 2011
    • 506
    Hi all a while back the esc in my mono had a melt down . The hull is birch ply with the inside sealed in West systems epoxy. Which cleaner should i use to remove the black goo inside the hull and to get rid off that burnt smell? Regards Andris Golts.
  • raptor347
    • Jul 2007
    • 1086
    Denatured alcohol. Trust me, it works wonders.
    Brian "Snowman" Buaas
    Team Castle Creations
    NAMBA FE Chairman
    • photohoward1
      • 1614
      I have always had luck with Oven Cleaner too.
      • electric
        • May 2008
        • 1744
        Alcohol, it wipes off like magic...completely clean.
        • Andris Golts
          • Jan 2011
          • 506
          I thank you all for the excellent information. Regards Andris Golts.
          • T.S.Davis
            • 6228
            Fast Orange hand cleaner.
            Noisy person
            • cugino
              • Nov 2008
              • 136
              Aceton or Isopropylalcohol. Always worked well for me.
              -= MHZ Shockwave - MHZ Micro Fountain - MHZ Cougar 2 - "Orange cat" =-
              http://olaf.webz.cz
              • Shooter
                Team Mojo
                • Jun 2009
                • 2520
                Once you get the black off, you will probably still have the 'odor'. Some people actually like this odor, which is beyond me. Anyhow, I dumped 2 boxes of baking soda in mine and let it sit in the garage for 2 weeks (shaking it every so often). Worked wonders.
                • T.S.Davis
                  • 6228
                  MMMMMM.......nomnomnom. I usually scrape out the debris and roll it in like a filthy animal. That's just me though.
                  Know what that smell is?............the edge.
                  Noisy person
                  • carlcisneros
                    • Jan 2010
                    • 1218
                    OMG!!!!!!!!!!!!!!!!!!!!!!!!!!!
                      • 7990
                      Aceton or Isopropylalcohol....
                      Bad idea on the acetone. Acetone can/will dissolve epoxy - meaning that an epoxy/glass hull can be softened, or motor mounts and servos glued in with epoxy may come loose if exposed for too long to the solvent. Alcohol is much safer and removes most all of the smell too. Hint: use a toothbrush on the textured inner surface of fiberglass hulls to get out the black goo remaining in the glass weave.
                      • Shooter
                        Team Mojo
                        • Jun 2009
                        • 2520
                        ha! I knew you were one of 'em! You and the guy that works in the returns dept. at Castle!
                        • T.S.Davis
                          • 6228
                          Can you imagine what that guy smells like when he gets home? I always packed them in a ziplock so they didn't have to smell em too...........after I finished making tea from the remains of course.
                          If your on the drivers stand and you smell something burnt but don't see anything burning...............it's me.
                          Noisy person
                          • ray schrauwen
                            • 9438
                            Ditto on this and afterwaRDS I used a Norwex solution that took all smell out.
                            Oven cleaner gets crap out, use a cheap baby bottle brush for nooks & crannies..
                            • Raydee
                              • May 2007
                              • 1603
                              My buddy used Electric motor spray on his burned mess yesterday and he said it worked great.
                              Team Liquid Dash
