Turbo jet 150a esc
  • GatorsFan
    • Aug 2012
    • 34
    Turbo jet 150a esc
    I have a turbojet 150a esc and a spektrum dx2 i can enter the progamming feature of the esc and set all the parameters once i save everything it gives me the tones and restarts the esc. Once this is done i have steering but cannot get the motor to arm any suggestions on what to try?
  • jamespl
    • 742
    Throttle reverse?
    • electric
      • May 2008
      • 1744
      and try turning the trim up or down until you hear the beep of the motor arming. Also check your End Point adjustments.
      • GatorsFan
        • Aug 2012
        • 34
        trims have been adjusted throttle reversed and end points checked with no luck seems that now when i turn on the esc it beeps twice then goes silent if i squeeze the throttle it goes into programming mode battery is a 2s lipo fully charged
        • jamespl
          • 742
          It might not be compatible with 2s some esc's are 3s and up or it may just be a duff. I had a cheap HK one and it worked twice after that I could program it but it wouldn't arm.
          • GatorsFan
            • Aug 2012
            • 34
            claims it will work with 2s but who knows i have two of the esc and both do the same thing think i may just get the hobbywing seaking 180 and call these a loss cuz i dont want to take the time and hassel to send them back
            • GatorsFan
              • Aug 2012
              • 34
              i may have found the problem i noticed in the programming mode it does not beep the option for 2s so im wondering if indeed it will not run on 2s going to make a series cable so i can hook 2-2s packs together to make a 4s and see what happens. well that is what the problem was put 4s to it and it now works odd since the esc says 2s-6s
                • 7673
                I have what is probably the same ESC.It is called SkyWing.And a buddy just got the same one as you. On the Skywing I could only get it to aknowledge Nimh mode.Which is fine if you keep an eye on the run time.
                • GatorsFan
                  • Aug 2012
                  • 34
                  it dont really matter to me that i cant get it to program to a 2s pack as i was planning on using at least 4s pack anyway
