Bench testing my Zonda twin
  • sampit
    • Jul 2009
    • 447
    today was the day I got round to bench testing
    Problem is only one motor starts up I have checked both escs and they both work fine
    It looks like the problem is when I in conect the y lead I tried removing one of the red wires but then no light on the beck and no motors work FC 8s 250A escs 4s2p 8000 mah, trackstar 4068 2650kv motors
    I have added a picture wondering if anyone can help
    Thanks in advance
    Sampit
    Just to add when I tried each motor on there own one started pretty fast but the other I had to hold full throttle for around 6 seconds
    FC Cheetah TP4092 1600KV Dinogy 6s2p,Etti Envoy WE 3s, Rico Mono 31" T600 1400kv Dinogy 5100mAh 65c 6s1p
    Popeye Hydro T600 1400kv 6s1p
  • lenny
    • Sep 2010
    • 4294
    Did you calibrate the throttle on the tx and esc's,
    And check that the esc are programed right and the same ?
    Also try reverse on the tx and see what happens.
    ? ONLY IF THEY WORK
    • sampit
      • Jul 2009
      • 447
      Little bit further
      looks like one motor is starting up after around 2 seconds of full throttle
      but the other one I have to hold for around 12 seconds not good!
      I had to remove the drivelines on both motor to test but i got them both starting up
      But I'm I getting five beeps after the main hook up beeps
      Hold full throttle after 12 seconds they both motors start up as normal, it just when I first hook the packs up
      both esc are set the same settings
      would be a bit scarry holding one motor a full power until the other one fires up
      Especially with drivelines conected and props on.
      Is they any way set both escs to fire at the same time ?
      Both escs are set to 1.5 s throttle delay
      • b20btec
        Senior
        • Aug 2011
        • 252
        Sam,
        If you're holding one for more than 12 secs your esc's are not programmed the same. Turn ON your reverse when programming. The 12 sec delay is built in when you have reverse OFF.
        • lenny
          • Sep 2010
          • 4294
          When you calibrate the throttle on the tx and esc's,
          You need to do one motor and esc at a time to.
          And then program them, Pretty sure on that.
          ? ONLY IF THEY WORK
          • znus
            Broke, as usual
            • Jun 2011
            • 120
            I can't be of any help but I just gotta say I'm intrigued by those motors, 6-pole and all. Nice work with the cooling jackets and I hope you'll figure it out. Can't wait to hear some feedback on those motors!
            I had more success calibrating both esc's at the same time with an y-lead (SeaKing 180's that is, not sure how the FC's act). Otherwise it was impossible to get them to start at the same time, with maybe 1 second of delay from one to the other. 12 seconds delay between the two will be.....difficult
            25" Arrowana with Etti 2970 3300kV. RCMK Flying Cat with twin HOR Outboards. 2 x SSS 4092 2140kV. Faluga 45" with Leo 56110 620 kv on 12s.
