Run time question
  • dereckg
    • Jul 2012
    • 153
    Run time question
    Being new to boats Im not sure what kind of run time I should expect ?? My set up is 120 amp esc with a 3674kv motor I plan to use two 2s 5000mah 40c
    drive it like you stole it !!
  • driftah
    • 760
    expect around 5min area,what hull? I suggest running a 4s2p setup if u have room due to a higher availability of amps and runtime....if thats what u are goin for that is? careful of the prop and setup if you are gonna be runin 4s1p as batts like to go pufffff sometimes.
    • madmikepags
      • Aug 2012
      • 1359
      3674 kv motor is a 2-3s motor 4S is asking for BOOM!!!! 2500kv is on the crazy high end of a 4S setup.
      We call ourselves the "Q"
      • dereckg
        • Jul 2012
        • 153
        The set up is in au thunder tiger outlaw obl Previous owner ran with 4s and said it was under powered
          • 9488
          what kv and prop ??
          • dereckg
            • Jul 2012
            • 153
            3674 kv with a prather 225
            what kv and prop ??
            • dereckg
              • Jul 2012
              • 153
              when you gona sell one of your cat. UL's
              • ezhitz
                • Aug 2009
                • 428
                Just a thought do you mean that its 3674 leopard motor
                :canada
                • siberianhusky
                  • Dec 2009
                  • 2187
                  Thats a setup waiting to explode! Way to high a kv for 4s.
                  I hope you have a 3674 sized motor and are unsure of the KV.
                  There is no way you even want to try to run a boat at over 50000 rpm! If you do make sure to take video of it's one and only run! Will be an impressive smoke show!
                  • dereckg
                    • Jul 2012
                    • 153
                    I bought the boat here and is listed as Thunder Tiger Outlaw obl mono with 120a esc and Tacon 3674
                      • 9488
                      3674 is the can size.. KV is the rpms
                      post a link to the add and we will see the motor..
                      uhm, maybe within 24hrs
                      • dereckg
                        • Jul 2012
                        • 153
                        FS: Thunder Tiger Outlaw OBL 40" Mono / 5s 40c batteries / Props. Was listed on 7 23 If you can link this not to comp. savoy Im sure im not giving correct info.
                        • siberianhusky
                          • Dec 2009
                          • 2187
                          most of the time you want a 1800 to 2200 kv motor for running on 4s, this will give you an unloaded rpm of aprox. 26000 - 32000 depending on KV.
                          Depending on the version of Tacon motor and the KV and only having 5000mah on board you could have very limited runtime.
                          Fully charge your batteries, run the boat for one minute solid. Bring the boat back in and charge the batteries again, a decent charger should tell you how many mah went back into the battery after 1 minute of runtime. Remember you don't ever want to run your batteries below 20% capacity, this means you should never put more than 4000 mah back into your 5000mah batteries.
                          Now that you know how much you used in a minute it easy to figure out how long you can run and still have at least 1000mah left in those batteries when you're done a run.
                          With that prop depending on the KV of the motor I think you'll find you can run about 3 minutes and still have a good margin of safety left in the batteries. Once you get it dialed in you may find you can get longer runtimes.
                          When you do your first one minute run make sure to check the temperatures on the batteries, esc and motor. If they are hot you will need to get a smaller prop. To be safe run it for 2 minutes the next time and charge, the more data you collect the more accurate your estimates are.
                          Personally I'd get a smaller prop to start with, always better to start small and work your way up. It doesn't take long for a bad setup to blow up an esc.
                          • lenny
                            • Sep 2010
                            • 4294
                            This is his boat he got,
                            (120a esc and Tacon 3674) it ran 40-45mph consistently on 5s. With the right motor and esc this would be a great boat for high speeds and still be stable.
                            Hears a links,http://forums.offshoreelectrics.com/...ops&highlight=
                            http://forums.offshoreelectrics.com/...ger-Outlaw-OBL
                            ? ONLY IF THEY WORK
                            • dereckg
                              • Jul 2012
                              • 153
                              You are correct thank you
                              Hears a link.http://forums.offshoreelectrics.com/...ger-Outlaw-OBL
