trim tabs needing to be flush?
  • driftah
    • 760
    I have a question about trim tabs...how much does it matter if the tab when at 90 deg. sits level with bottom of hull,as in if the trim tabs were mounted a little high on a transom would this cause any issues.I ask because I have a boat that has tabs mounted up higher and they have to be screwed down far in my opinion to meet the bottom of transom line?
  • Make-a-Wake
    FE Rules!
    • 5557
    Tabs need to be about 3-4mm above the bottom of the transom............never flush.
    • marko500
      • Aug 2008
      • 861
      My SV27 when new had the trim tabs mounted way above the hull bottom. I took them off and elongated the holes with a small round file until the tabs were almost even with the hull bottom. Alot easier and neater then redrilling the transom.
      • cpgise
        • May 2010
        • 90
        Mount them about 1/16 to 1/8 inch above the bottom of the hull.
        • martin
          • 2887
          If you mount them level with the bottom of the hull they create more drag, as been said mount them up from the bottom.
          • T.S.Davis
            • 6220
            Really? I've never mounted my tabs above flush.
            Noisy person
            • driftah
              • 760
              ya odd my df29 has them mounted about 1mm above flush and it is a bullet,I notice zero drag but hey its worth a try movin them up a touch maybe.
