Is this motor dead, fried, caput?
  • gyrotron
    • Jul 2012
    • 481
    Hi Guys,
    I just run my Outlaw Jr this morning and after the 1st run the boat stalled in the water, then run again and stalled once again. I brought it ashore and out of the water tested the motor and it kept stalling. Inspected collet, and propeller shaft and they looked fine. I disconnected everything and then manually rotated the propeller shaft clockwise and it seemed to do fine then counterclockwise and it got stuck a few times .
    Thx
  • gyrotron
    • Jul 2012
    • 481
    bump
    • TheShaughnessy
      • 1431
      If it stopped working there is a good chance it is burnt up. What does it smell like
      • gyrotron
        • Jul 2012
        • 481
        TheShaughnessy,
        Actually I fixed the issue today. Since none of the electronics smelled burnt, I went ahead and unmounted the motor, disconnected the ESC and in the process found the black bullet connector was super loose so I adjusted the contact groves with a mini flat head screw driver and reconnected back. I also took the oportunity to disassemble the motor, clean the inside and oil the bearings so now is running like a champ .
