T600 Outrunner on 8s
    • 9479
    just looking to see if anyone has tried a T600 outrunner on 8s
    wonder what a 910kv on 8s in a DF39 running a X447/3 or bigger might be like?
    thanks
  • Make-a-Wake
    FE Rules!
    • 5554
    Sounds like it would be a solid setup to me.
    • ray schrauwen
      • 9438
      8S1P? You mean the chrome & red motors or the black & red bigger ones??
        • 9479
        not sure what motor is better Ray?
        8s1p should be plenty..
        • ray schrauwen
          • 9438
          The Red & black is slightly larger and rated slightly higher in watts. The 910Kv might be more to your benefit since the larger one doesn't come in 910KV, just 880, 1100 and 1400...
            • 9479
            don't need exact 910kv
            the 880 would work great, and the 1100kv would be a screamer!
            so if you all think I won't smoke the motor I may give it a try
            I'm looking for mid to upper 60's
            • ray schrauwen
              • 9438
              At this point you may be on your own. Upper 60's from these motors might be difficult. Possible but, I've only dabbled with the 1400KV version on 5S2P in a heavy 29" (3.5lb empty) Promise hobby cat. I was turning a D/T x450 prop for 6-7 laps. Poly RC 25C 5000's in parallel. Ran like a champ in Open Cat.
              Close to 55mph. You should use a hefty water cooled motor mount like the Vantex brand to help dissipate heat. They are approx. $7+ shipping. I have a couple extra.
              Now if you are using 40C-65C at least and 1P, you might get there. I really need to build my twin CAT witH 880's...
              Think I'll get another 1400kv and get that cat going again.
              25C 5 year old PolyRc cells vs 25C new Nano's and the nano's lost, burnt up. POly's still going, zero swell. Go HiC or go home.
