Hi again, so, my title asks everything, whats the difference between these motors:
1. Motor:
SSS water cooled 2075KV 3674 4 pole
Type: 3674
Kv: 2075
Y/D: 4D
Max Amps (A): 82
Max Volt (V): <29
max power (w) 2400
max rmp: 60000
nonload current (a): 2
shaft diameter: 5mm
2. Motor:
Leopard 4082 Motor 4 Pole
Type: 4082
Kv: 1600
Y/D: 2Y
Max Amps (A): 120
Max Volt (V): <33v
max power (w) 2000 with Over 3500 Burst
max rmp: 60000
nonload current (a): (i dont know)
shaft diameter: 5mm
other informations: i want to run a twincatamaran with the motors, each for one side (1 motor, 1 esc, 1 prop per side) 5s lipos 500mah 50/100c, wich motors are better and faster for it? the Cat is 41" long.
1. Motor:
Type: 3674
Kv: 2075
Y/D: 4D
Max Amps (A): 82
Max Volt (V): <29
max power (w) 2400
max rmp: 60000
shaft diameter: 5mm
2. Motor:
Type: 4082
Kv: 1600
Y/D: 2Y
Max Amps (A): 120
Max Volt (V): <33v
max rmp: 60000
shaft diameter: 5mm
