Warning: Trying to access array offset on value of type null in .../vb/bbcode/url.php on line 114 Warning: Trying to access array offset on value of type null in .../vb/bbcode/url.php on line 114 Low profile stinger? - Offshore Electrics Forums
    • 7673
    OK guys,I need some help here.I have a cat hull here that I'm thinking of twinning.It does not have much room on the transoms for stingers.Somewhere on this web I recall seeing some that only had through bolts on the sides of the stinger and not a third on the top.I'm sure I saw them but I can't find them anywhere. Perhaps one of you guys may know. Thanks in advance, Shawn.
    • 7673
    Well I guess these are them http://www.ebay.ca/itm/70mm-adjustab...item1e60e7f313
    So next issue,can I do a 150 flex to a 4mm shaft?So I can go one piece flex.
    Or has anyone enlarged a 4mm stinger to accept a 3/16 bushing.
    • dana
      Banned
      • Mar 2010
      • 3573
      Seems to me you could put the stinger in a vise and drill it to whatever size you need with ease
      • Mattwarner
        • Aug 2011
        • 487
        I have these stingers on my Rivercat, the stock 4mm bushings can easily be knocked out and i replaced with 3/16 speedmasters, they fitted perfectly without any drilling and just a drop of loctite to secure.
        Originally i used 4mm shafts and .130 flex, i was told .150 would fit but it was a pain to do, 3 broken flexs later and replaced the whole lot with 3/16!
        • znus
          Broke, as usual
          • Jun 2011
          • 120
          @mattwarner. That is a seriously good tip!! I have that stinger x 2 on a cat and the stock bushing are of the worst quality I have ever seen. The 4 mm propshaft just warbles around in there. Did you buy the Speedmaster bushings on OSE? If so - which one of the two?
          http://www.offshoreelectrics.com/pro...=ros-spdsd-187
          or
          http://www.offshoreelectrics.com/pro...s-spds-014-bsf
          25" Arrowana with Etti 2970 3300kV. RCMK Flying Cat with twin HOR Outboards. 2 x SSS 4092 2140kV. Faluga 45" with Leo 56110 620 kv on 12s.
          • Mattwarner
            • Aug 2011
            • 487
            I used the first ones, i didnt buy from OSE as i am in the UK but they are the same made by speedmaster and are a perfect fit, whatever you do DONT try and hammer them out using a screwdriver! i ended up with this!
              • 7673
              Haha I remember that from another thread.So I guess an appropriate sized dowel or pin is best?
              Thanks Matt.
              Well if it is just the bushings then it may work for the Promise Hobby stingers as well.Then I will be in business.31 mm is going to be too tall but the PH ones are 24mm and they should just work.
              • dana
                Banned
                • Mar 2010
                • 3573
                Matt, what do you mean you used locktite?
                • Mattwarner
                  • Aug 2011
                  • 487
                  Once the original bushings have been (carefully) drilled/pressed out, the speedmaster bushings slip in but you need to apply a bit of loctite to the bushing and leave to dry so they don't spin in the stingers
                  • dana
                    Banned
                    • Mar 2010
                    • 3573
                    Correct me if I'm wrong, but aren't the speedmaster Bushings designed to float/spin freely?
                    • driftah
                      • 760
                      mine spin freely,in both my boats...and slide out for easy lubing
                      • dana
                        Banned
                        • Mar 2010
                        • 3573
                        As they should. If I were doing the stinger posted, I would drill them out with 1/4 bit, then run the 1/4 brass tube into them, then just insert my bushings. They should spin based on design
                        • Mattwarner
                          • Aug 2011
                          • 487
                          Really? That I didn't know! So the bushing should be loose to spin with the flex?
                          • dana
                            Banned
                            • Mar 2010
                            • 3573
                            Yes sir
                              • 7673
                              Yup,I guess that is what I will do then.Just some careful drilling.
