genesis setups, curious
  • iridebikes247
    • Dec 2011
    • 1449
    Hey I bought a genesis hull not long ago, just wondering how most people set them up. I have a lot of zippy 5s 5000 mah packs (so 5s 10,000 mah)and would like to run a turnigy 180 esc, any ideas on motor/prop? I would like to go leopard 4082 or 4092 depending on what others have done.
  • JonD
    • Jun 2011
    • 129
    My suggestions if you are wanting to using 5S packs :-
    Leopard 4082 1800kV or 2000kV
    Turnigy 180 ESC
    0.150 flex with 3/16 prop shaft
    M445 or M545 prop
    Offset rudder
    Cheers,
    Jon
    • iridebikes247
      • Dec 2011
      • 1449
      Ya I was thinking the leopard 4082 1800kv, I run two 1600kv motors in my cat and they're great.
      • 1945dave
        • Mar 2012
        • 304
        Listen to JonD. I have made a mini career at building, rebuilding and modifying the Genesis and can tell you from lots of experience 5S is just about the perfect battery configuration and the Leo 4082 1800kv pushing M445 props nearly perfect as well.
        Dave
        • SirBudman32
          • Aug 2011
          • 625
          I have a CC 1515 - 2200, T-180 Running (2) 5s 5000 Zippy's with a m445 in my Genesis.
          Modified Jae21, Stock Jae21, Cheetah, Ul-1, Shock Wave 26 V2 (Rescue Boat).
          • 1945dave
            • Mar 2012
            • 304
            Any chance do you know what kind of amps you are pulling or any other performance information?
            Dave
            • SirBudman32
              • Aug 2011
              • 625
              As far as Amp's I have no idea. I know on a 85 degree day everything was under 105 degree's. As far as performance, First time I really got to run it hit 47.2 on Gps. with strut level with ride pads and offset rudder. Had hard time getting it to go straight, hooked to the right Hard. just did a couple mods to the rudder and strut to try get it to go straight.
              • motorfixer1
                • May 2012
                • 36
                I am running my genesis similarly to the above suggestion.
                Leo 4082 1800kv
                T180 with extra cap bank
                x445
                3/16 flex and lined tube
                6s2p nanos 6600mah
                stock rudder and placement
                Here's the link to the rebuild: http://forums.offshoreelectrics.com/...ild&highlight=
                • iamandrew
                  • 577
                  you got any pics of the batteries in this boat Motorfixer ?
                  • motorfixer1
                    • May 2012
                    • 36
                    I do have some photos of the nanos in the genesis. They barley fit in the sponsons and only fit one way in and out. The most battery the genesis can handle as far as I am concerned.
                    • Make-a-Wake
                      FE Rules!
                      • 5557
                      Turnigy 180 ESC
                      M445 or M545 prop
                      Offset rudder
                      Cheers,
                      Jon
                      I think Jon nailed it..................I'd go with the 445
                      • iamandrew
                        • 577
                        ah cool, yeah i notice the nanotechs are definatly smaller size than other batteries,
                        ive got zippy 5S flightmax and they just fit
                        • Make-a-Wake
                          FE Rules!
                          • 5557
                          Zippy has a new line of "compact" lipos. I have a set and like them just fine, I fit 3s2p 6600mah in a 23" DF Mini sniper.
                          Here are some 6s 3300's in the compact, same voltage and mah as your Nano's, height is much less
                          Zippy compact:
                          Length-A(mm) 148
                          Height-B(mm) 37
                          Width-C(mm) 44
                          Turnigy Nano:
                          Length-A(mm) 145
                          Height-B(mm) 53
                          Width-C(mm) 37
                          http://www.hobbyking.com/hobbyking/s...ipo_Pack_.html
