I get about 7 min of run time with about 50% left in the batteries. As for the 2000kv you should get high 40's easy with that setup.
Areo Marine Mean Machine.
Here are some of the esc and caps:Attached Files24 R/C vehicles and still counting...What budget?Comment
i have a hobbyking 4074 2000 kv on 4s2p (gens ace 4000 mah 4s 25c packs) in a miss geico that is doing 50+. a 42x55 prop got me to 47.8 and with an m445 i got up to 54.3. Sure there is more speed to be had. similar size boat so i'm sure you could get 50+ in a MM. I don't tend to run longer then a few minutes at a time though.Comment
What a coincidence...I just priced out the same boat, hardware and motor but haven't decided on the ESC yet. Now I figured using a 6S pack but it appears that everyone is using either 4 or 5S packs in parallel. I'm considering the Leo 4082 motor but haven't decided on the either the 2000KV or 2200KV. I definitely want it to run in the 50s.
Has anybody any experience with the ETTI speed controls yet?
Would an ABC H7 prop work with this set up?Comment
I ran the etti 150 with a 4074 2200 kv on 4s, the caps bulge, get some extra caps for sure. Otherwise its a good esc, but the seaking is cheaper and a higher amp rating...
Edit: As for the prop I don't think that would be a good choice since the pitch is very high and the diameter is too big. If you want to run 6s2p try the leo 4082 1250kv. I am getting 55.4 mph out of the leo 4082 1550kv on 5s2p 10000 mah total m545 prop.Last edited by Rich; 08-20-2012, 11:42 PM.24 R/C vehicles and still counting...What budget?Comment
Sorry to raise an old thread but I am building a MM now and I was hoping to use my Seaking180 and 4092 1430KV running on 6S most are saying it should fly but am I going to be too heavy? I ordered Kevlar matting and more fiberglass for the front ½.Comment
IMO you won't have to worry about the weight with that setup. You will have plenty of power! Your boat will fly!!! I bet you will be able to break 60mph
EDIT: get extra caps for the seaking and start with a x445 or m445 prop or lower.24 R/C vehicles and still counting...What budget?Comment
Dana m445 with my 1430? I was going to start with a x646. Also to get your strut up 1/4 did you have to take some material out? Mine is bottomed out with it flush. Just sees odd that they would boy have any adjustment for a positive positionComment
Traeside, yes the m445 with the 1430 to start. I am running an m545 on a leo 4082 1550 kv on 5s2p and pulling in the 155-165 amp range. Do you have a link to your thread with some pics of the back end? You may have the strut mounting bracket too low?24 R/C vehicles and still counting...What budget?Comment
