Anyone running endurance?
  • sjslhill
    • 1513
    Anyone here running for say 30 mins? Is it even possible? Does heat build up cause problems? Anyone running 10 mins?
    thanks,
    Steve
  • dana
    Banned
    • Mar 2010
    • 3573
    I think you would need say, 4s2p2p lol
    Parallel a parallel setup
    • boater57
      • Feb 2012
      • 23
      I get 7 minnutes or less on my 4s setups, (EKOS, MC) but can get 10 min runtimes if I just part throttle it with a few speed runs between.
      • iamandrew
        • 577
        you might have no grease left in the drive shaft after that long and you might end up with a bit of water in the boat
        • sjslhill
          • 1513
          Don't get the grease comment, maybe things have change. I run teflon and never have this problem.
          • iamandrew
            • 577
            Even with teflon, when theres no grease in the tube, water will come up the flex shaft after running the boat for more than 10 minutes if you dont have an Oiler, and seeing you are using teflon, you probably dont have that setup either
            • dana
              Banned
              • Mar 2010
              • 3573
              why dont i ever have this problem?
              • sjslhill
                • 1513
                Ran Ed's teflon into the strut for years and never had a drop of water ever. I am guessing you guys are running wire drives and that's why it's leaking.
                • iamandrew
                  • 577
                  I just wouldnt be comfortable running my boat for longer than 10 min and not being able to look inside it thats all....
                  • Rumdog
                    • 6453
                    I'vr ran gassers for 1/2 hour at a time. Grease isnt going to be a problem. Teflon, of not.
                    Long run times... 2p HV setup low kv motor with a conservative prop. 10 minutes.. sure, why not?
                    • siberianhusky
                      • Dec 2009
                      • 2187
                      Don't they runs some long races in europe?
                      • properchopper
                        • 6968
                        Endurance runs, or just 10+ minutes runtime would force the "Iwannagofaster" or wannabe "SAW setup" runners to learn some refined setup/equipment skills. Big difference between a 4.5 minute Offshore setup and a ZSP/WTS? * Banzai run.
                        *[ZoomSplashPlop/What'sThatSmell?]
                        Personally all my nerves can take is a 2.5 minute 6-lap heat, but that's just me
