Prop size on a 8XL and Hydra 240 ESC?
  • 10gauge
    • Aug 2007
    • 281
    I know that a Hydra 120 ESC is not up to the challenge of running an Feigao 8XL on anything above a 440 prop. However, what if a Hydra 240 ESC was used on an 8XL motor, up to what prop size can one use and still keep within the temp and current limits?... x442, x445, x642?
    Mean Machine Cat: 9XL, 4S2P, CC120, M545 (50mph) -- DF22 Hydro: 8L, 3S1P/4500, CC120, x637 (49mph) -- M-1 SuperCat: 1521/1Y, 6S2P, CC240, x447 (61mph) -- SV27 Mono: stock setup, 14-cell/4200, x642 (42mph) -- Micro Scat Cat: 28-3600, 3S1P/2100, Turnigy 60, x430 (41mph)
  • Mich. Maniac
    Banned
    • 1384
    I could be wrong but, feigao xl 540 motors cannot even handle 120A continous. They should be run around 70A max. At least that is what I have read. I have even read they should be run at 60A cont. I see no reason to run a hydra 240 on a feigao motor.
    • Mich. Maniac
      Banned
      • 1384
      Steven has posted some simple numbers here, I even think his numbers on max ratings are a little high. They will take abuse but only for soo long. here is what I am talking about.
      http://www.offshoreelectrics.com/fei...tors-chart.php
      • Raydee
        • May 2007
        • 1603
        I run a 7XL in my rigger and one in my Whiplash both on Hydra 120 controllers and have no problems. If you do plan to use big props just watch your temps or for less than $100 more just get the 240 and have some head room.
        Team Liquid Dash
        • Mich. Maniac
          Banned
          • 1384
          How many amps do you think your rigger is pulling with 7xl? prolly not too many. I guess it doesnt matter what the specs say. Push 160A through a feigao. its your money!
          • 10gauge
            • Aug 2007
            • 281
            Thanks Mich and Ray! I have burned a new Hydra 120 in a Mean Machine Cat with 8XL, 4S2P, and a x445 prop. That's why I thought perhaps a Hydra 240 could give me a safety margin. From now on I am going to delegate my 8XL only to hydro setups.
            • Raydee
              • May 2007
              • 1603
              My EagleTree logger says I am in the 85-90 amp range with peaks of about 110.
              Team Liquid Dash
              • Mich. Maniac
                Banned
                • 1384
                Really? that just doesnt seem right. I know your not new to this but sounds like their maybe something wrong with you setup. IMO a 8xl and hydra 120 should be perfect for MM hull. save some money and just use a 9xl with the same voltage and get your 120 repaired. should spin x445 ok.
                • Mich. Maniac
                  Banned
                  • 1384
                  Then you are right where you should be. As far as HIS setup. pushing a feigao motor anymore than 120A just isnt good for anything. I wouldnt think even on MM hull that amps would be over 100A. Again I guess it would come down to getting it logged as you have done.
                  • Raydee
                    • May 2007
                    • 1603
                    Well in any hull if you are running wet you can draw way to many amps. Cats have a lot of drag in my opinion and unless the boat is up and out of the water you can easily pull some serious amps.
                    Team Liquid Dash
                    • Jeepers
                      • May 2007
                      • 1973
                      I may be wrong but I think even a 445 is to big even for a 9xl now a 442 thats a better choice IMO
                      • Doug Smock
                        Moderator
                        • 5272
                        FWIW
                        I ran a wc 8xl in a Titan 29 on 4s2P while my 1515 1Y was in for bearings.
                        Ran the same prop (640) and the temps were nearly identical. Cells 117, esc and motor around 125. The load on this setup is 128 amps. per Eagle Tree.
                        The boat was not quite as fast but did well.
                        NOTE: This is a free running mono!!!
                        Doug
                        MODEL BOAT RACER
                        IMPBA President
                        IMPBA 19887L CD
                        NAMBA 1169
                        • properchopper
                          • 6968
                          re :
                          This is a good thread; it also lends support to Mr. V's suggestion to start a Setup section where we can share our trials & [costly ] errors
                          Fwiw, I've run a watercooled CC 80 with a 8XL for over a year now in a OM26 with no prob's [ 12 & 14 cells, lately 4S. ] Keepin' the props small : X637, P 215, lately a X640. The big factor for me is runtime; I keep it short for fun running. Usually never over 3 minutes[ I use a timer]. Heat builds up exponentially so I've learned to limit my "hot setup's" runtime drastically.
                          I have other Hydra/Feigao setups to share; let's get the "setup section" going !
                          • ReddyWatts
                            • 1711
                            I agree 10gauge. You will need a controller larger than a 120 amp in a cat, if you use a prop bigger than the X440. These motors are rated at 800 watts, but have been run successfully to around 1800 watts. Watch your max watts and temps.
                            ReddyWatts fleet photo
                            • Jeepers
                              • May 2007
                              • 1973
                              also note that a bound up driveline will pull more amps regardless of prop size or how loose the hull is.
                              Today a club members hydro running a SV27 motor, motor came in at 220 running a x440 2 blade prop.
                              I think its cause the drive/builder opted to use a S bend in the driveline.
