Are there special receivers for boats?
  • pfish
    • Jul 2012
    • 25
    I have a inexpensive tower hobbies transmitter with receiver. The included receiver has an internal antenna. Tower hobbies tech say it will work fine.
    I will place the receiver in a water tight compartment. I'm concerned that there is no external antenna and whether it will be adequate.
    Any opinions?
  • JimClark
    • 5907
    do a range check
    Billy Graham
    • runzwithsizorz
      • Jan 2009
      • 896
      This is the police! Put the receiver down, and slowly back away.
      • BHChieftain
        Fast Electric Addict
        • 1969
        The spectrum mr3000 and mr200 are water resistant, and also have nice long dual antennas for dual diversity. Getting the antenna up out of the hull is a must for carbon fiber hulls (which block 2.4ghz, but also recommended for any hull since water also blocks 2.4). I've heard people use the tactic rx w/o the antenna wires successfully, maybe just try to place it as high as possible in the hull away from the waterline ( I still would not use it on carbon fiber hulls).
        Chief
        • scottw
          • Dec 2011
          • 49
          Agree with the Chief
          the spectrum mr3000 is bullet proof - water proof!!!!!! - -
          Dual antenna - a must
          Scott
            Dual antenna - a must...
            Where do people come up with this BS? Dual antennas are not required at all - but if your particular receiver has them don't cut one off. Spektrum's first 2.4 gig radios did not work very well in boats (I had some of the first) and they were forced to do a re-design to make them reliable. Adding another antenna was one band-aid they used - and they still have to have "marine" receivers since their "car" receivers are not that reliable in boats (so they say). Most other radio manufacturers don't need "marine" receivers.
            My Futaba 4PK receivers have a single antenna and they work splendidly out to "is that a boat out there?" range. Several club members run the Spektrum receiver with dual antennas - and they keep the antennas inside the hull. I don't recommend this, but it certainly works for them (large tall boats BTW). The Tactic radio used in AquaCraft RTR boats is good without an antenna - I was dubious at first, but they work to a surprising range.
            As stated in the second post - do a range check to see if it works in your particular hull. It may only give 100 yards of range - but that's plenty for most boaters.
            • Steven Vaccaro
              • 8723
              I personally think the Spektrum mr3000 is the best thing to happen in boat receivers. 100% water proof. They are expensive. But so would be a wrecked boat that looses control after using a standard receiver that got wet.
              • scottw
                • Dec 2011
                • 49
                Jay
                Its just an opion that whats make this Forum so great
                We use what we use - we all have our favourites
                scott
                • drwayne
                  • May 2008
                  • 2981
                  @everyone.
                  I use Futaba 603FS with one internal, one outside cabled antenna.
                  No problem
                  @everyone
                  I use the Spektrum's waterproof mr3000
                  no problems
                  @everyone
                  If you need waterproof receivers, you should learn to build better
                  :peace:
                  • Steven Vaccaro
                    • 8723
                    Originally posted by drwayne
                    @everyone
                    :peace:
                    Funny Man. I'm sure you never get water, even a drop in your hulls.
                    • oscarel
                      • Dec 2009
                      • 2128
                      I've had both a futaba 603 and flysky receivers submerged and they worked fine afterwards. I made sure to coat them with corrosionx before and after using though.
                        Actually Steve, I almost never get more than a drop or two in my race boats. Ditto for most of my racing companions. Not all boats can be made completely waterproof, but most can be. After seeing so many FE boats over the years from across the country, I am shocked at how little most folks pay attention to keeping water out of their boats. Some seem to think that a couple of ounces of water in their hulls after a run is just fine (BTW it is not). The Dr. has a good point - although being speared by another boat and breaching the hull is a completely different matter.
                        I dont use waterproof receivers, but for those who can't build a half-dry boat they are important. I do spray my receivers and ESCs with CorrosionX (see last line in paragraph above).
                        Scottw - my issue was that if your post is read by a newbie it would be interpreted as an absolute. Use what you want and like what you want, but don't imply that there is only one receiver which works.
                        • drwayne
                          • May 2008
                          • 2981
                          are you goading me, mon sewer ?
                          @Ray. Ditto corrosion X inside everything electronic...Rx, servos, escs..
                          @steven. A few pin spirals of leaked water is the norm... Ive always paper toweling wedged in corners to catch whatever materializes.
                          As Ray points out, common sense, nothing prevents accident induced drownings... but that's racing.
                          DocW
                          • runzwithsizorz
                            • Jan 2009
                            • 896
                            "and they still have to have "marine" receivers since their "car" receivers are not that reliable in boats (so they say)."
                            I have a boat with the Spektrum telemetry receiver, (2" antenna), and have never had a range problem in 4 years. Even out to, "is that a boat out there?" range.
                            • BHChieftain
                              • 1969
                              I have 1 boat that I can't waterproof (1/10 shovelnose), so I put my RX in a Traxxas water resistant RX box (instead of a balloon). It isn't completely waterproof in my experience, but after multiple complete submersions, I've only had a few drops of water in the box once or twice. If you coat your RX first with corrosion X or liquid tape it should be pretty much bulletproof...
                              Steve sells those here:
                              http://www.offshoreelectrics.com/pro...p?prod=dh-3628
                              Chief
