Z-poxy????
  • LOVE6S
    • May 2012
    • 545
    Z-poxy????
    Hi guys, hope everyone is havn a good weekend, I am going to try my hand at some CF cloth laying, got all the stuff, but I think I ordered the wrong Z-poxy. I got the 30 min epoxy, I should of got the finishing epoxy, is that correct? Will the 30 min epoxy work ok to lay the CF? if not is there several options of stuff to get, or do I just order the finishing epoxy, thank you.
  • Heaving Earth
    Banned
    • Jun 2012
    • 1877
    You want the finishing resin for sure
    • LOVE6S
      • May 2012
      • 545
      Thanks bud.
        The 30-minute epoxy will not be thin enough to thoroughly wet the CF. Note that you want to use a minimum of the Finishing Resin when laying down CF cloth - you don't want a puddle of epoxy on the surface after you are done. I paint a thin coat of epoxy on the fiberglass surface, roll out the CF and use just enough epoxy to get it thoroughly wet. The grain of the CF cloth is raised and very evident. Too much epoxy and the strength will be reduced a lot. Ideally CF should be used with a vacuum setup to keep it 'tight' to the underlying material with a minimum of resin - tough for most of us to accomplish.
        • detox
          • Jun 2008
          • 2318
          Do a test by laminating carbonfiber vs. fiberglass. I believe you will like the laminated fiberglass better. I once laminated carbonfiber using Z Poxy finishing resin and it was very brittle (snapped in two pieces). Fiberglass would break, but stay together.
            I have crashed several boats at over 80 mph and not broken the CF loose from the FG. It sounds like you used 'way too much resin when laminating the CF onto your FG. BTW, using CF imparts stiffness to the hull, it is not meant to impart "strength". What you use depends on what you are trying to accomplish. Of course, plenty of folks just like the looks of CF in their hull - nothing wrong with that either.
            • iamandrew
              • 577
              the amounts of different people on this site seem to use a lot of different products, different types of epoxy etc. I have NO idea why people dont stick with stuff like West Systems 105 with a 207 hardener, it will do everything!
              • siberianhusky
                • Dec 2009
                • 2187
                I completely agree with the West comment, also much cheaper in the long run than buying all those small packaged bottles. I use it for almost everything with the appropriate fillers etc. The only other one I use is JB weld for installing stuffing tubes, bonds to roughed up brass like nothing else I've found.
                For a short while I used System 3 but went back to West once I ran out. No problems but West is thinner and wets out cloth better.
                • martin
                  • 2887
                  I use Zpoxy finishing resin & west, i also think the west is better. The Zpoxy does a pretty good job but not as good as the West, the West i think is stronger & not as brittle. I also use the various fillers & fibres that West offer depending on what job im doing.
                  • Heaving Earth
                    Banned
                    • Jun 2012
                    • 1877
                    i use zpoxy with good results. some of us are just learning and not so concerned with being able to drive over the boat with a tank.
                    • detox
                      • Jun 2008
                      • 2318
                      I built my first Whiplash 20 using the Z Poxy. I have since then hit several odjects in the water and boat has stayed together.
                      I now use this brand (127 thin resin and 350 hardener). I use fumed silica or micro balloons as fillers to thicken. http://store.raka.com/11/2quartepoxykit.aspx
                      • siberianhusky
                        • Dec 2009
                        • 2187
                        It's not about being able to "drive a tank over it". Ever see what happens when a motor mount rips out at full tilt? Quality adhesives with proper prep are very important in holding these things together with the power of even a spec setup, Think of the forces the mass of the motor is generating on the hull in a 45mph twisting and flipping crash. I bent the crap out of the stock Motley Crew mount in just such a crash. Dare you to jump off the back of a boat doing 45 mph, see how hard you hit the water! No different for one of these in a crash.
                        45 (or close to it) is within the capabilities of most of the modern RTR boats.
                        West isn't the only quality epoxy out there by any stretch, but most of the time it's available locally at marine stores or quality lumber stores, one of the reasons it's very popular is the wide distribution network.
                        • tlandauer
                          • 5666
                          I started to use the West System and I will never look back, I used 205/206 to stiffen the MHZ Xtreme hull. Great stuff, didn't use CF, just personal preferance, don't like dark color in the hull. For the transom, I mixed with there heavy filler , man, that stuff is strong.
                          My observation was that the Zpoxy is a very good quality product, but the difference beteen the 30 Min. Epoxy and the Finishing Epoxy is telling: I take the left over ( cured ) out of the bottom of the 1 oz. mixing cup, and the 30 Min. Epoxy is much stronger then the Finishing Epoxy, seems the latter is very brittle and is really intented to be used with some other strengthening materials such as CF or FG.
                          Just my $.02
                          • LOVE6S
                            • May 2012
                            • 545
                            I went to the site and checked thes stuff out, looks interesting, I like the idea of adding a filler to make a easy to work with past, but what does it cut your working time down to in a 30 min epoxy?
                            • siberianhusky
                              • Dec 2009
                              • 2187
                              No change in the cure time, The fillers are inert and don't effect the chemical reaction.
