FighterCat 41"Fantasm Twin Motors?
  • sampit
    • Jul 2009
    • 447
    I have three different motors I could possibly use in fantasm twin build, I will need to buy another motor to make up a pair, but what would be my best second motor to buy
    these are the motors I have already
    Leopard 4074 1400kv
    FC 3740 1760KV outrunner
    Trackstar 4169 2550kv
    will be running with 2 FC 2S/6S 300a ESCS?
    looking for a sports build and a speeds around 60mph
    thanks in advance
    FC Cheetah TP4092 1600KV Dinogy 6s2p,Etti Envoy WE 3s, Rico Mono 31" T600 1400kv Dinogy 5100mAh 65c 6s1p
    Popeye Hydro T600 1400kv 6s1p
    • 8011
    How many volts will you be running? IMO you will want the larger 40mm can motors, that's a big hull.
    • sampit
      • Jul 2009
      • 447
      Thanks Jay, all the motors are 40mm,I was thinking 6s for the leopard 4074 motors 6s2p, 5s for the 1760 outrunner and 4s for the trackstar motors, but not sure wich way to go may have to buy more lipos anyway.
        • 8011
        I meant 40mm can inrunners. I'd go with 6S, that will be easiest on the equipment and give longer run times. With x450s and the Leopards you should get 60 mph no problem.
        • sampit
          • Jul 2009
          • 447
          Ok, thanks i will use the Leopards on 6s, will I need use x450 CR props? if then can be bought CR.
          I also have spare pair of new T120 escs, would i get away with using them? save me using the bigger ott 300A escs.
          I can get x450 3 blade CR Props, but not 2 blade will the 3 blade be ok?
            • 8011
            Man, I can't seem to type what I'm thinking this morning! Use the x447 props L&R. I think that x450/3s may be too much prop as they are a big step up in loading over the x447s. See how the motors like the smaller props first before you step up in prop size. The 120 ESC is probably too small, a pair of 180s would be better.
            • sampit
              • Jul 2009
              • 447
              Ok thanks again, X447 L&R ordered shame about the T120S
