fightercat 300a ESC
  • worriedsick4u
    • Dec 2011
    • 693
    fightercat 300a ESC
    I have my esc programmed. When I connect the batteries I get a series of 3 beeps continuosly. ESC does not respond. Any ideas? And what is the 4 wire lead for? External BEC? Thanks guys
  • sampit
    • Jul 2009
    • 447
    After the beeps hold full throttle for around 7/10 seconds
    When the motor kicks in let go then you should be good to go
    You need to do this each time you connect the lipos
    I think the four wires are for conecting twin escs up
    FC Cheetah TP4092 1600KV Dinogy 6s2p,Etti Envoy WE 3s, Rico Mono 31" T600 1400kv Dinogy 5100mAh 65c 6s1p
    Popeye Hydro T600 1400kv 6s1p
    • worriedsick4u
      • Dec 2011
      • 693
      Thank you
      • sampit
        • Jul 2009
        • 447
        Did it work?
        • worriedsick4u
          • Dec 2011
          • 693
          Like a champ. Thank you
          • sampit
            • Jul 2009
            • 447
            I got two new ones I haven't used yet
            I read that they are a bit hit and miss
            Work really well or fry on the first run
            On 6s you need to keep a close eye on temps
            What setup you running it with?
            • worriedsick4u
              • Dec 2011
              • 693
              This is it....
              http://forums.offshoreelectrics.com/...-Supersport-45
              • carlcisneros
                • Jan 2010
                • 1218
                FighterCat ESC Instructions (latest version).doc
                the plug with the 4 wires are for firmware updates only.
                start at 5deg for timing and watch the temps closely.
                see the attached latest FC instructions.
                • worriedsick4u
                  • Dec 2011
                  • 693
                  Thanks Carl
