Speed estimate
  • Basstronics
    • Jun 2008
    • 2345
    Speed estimate
    I know its just a guess, but how fast do you think the rigger is going?
    I had fun realing in that hopped up SV27.
    I need a GPS
  • Alexgar
    • Aug 2009
    • 3534
    hard to say 45 maybe alittle faster
    • Make-a-Wake
      FE Rules!
      • 5557
      Do you know and this is simply a guess for fun? I think it's 52-55 mph.
      • Alexgar
        • Aug 2009
        • 3534
        i was gonna say 50 but i was being conservative
        • Basstronics
          • Jun 2008
          • 2345
          I was told with the setup and prop to expect 60-65.
          Motor: Leopard LBP3650 3900Kv
          ESC: Hobbywing 120A
          Batteries: SkyLipo 4000ma 40C 3S
          Prop: X632 by m4a1usr
          Honestly I dont know, yet. Next Wednesday Im ordering that mini GPS from Hobbyking though and having it shipped EMS. So I will know for sure.
          Ive GPS'ed my other boat at 43 before and this is faster than that for sure.
          • Basstronics
            • Jun 2008
            • 2345
            You win a cookie sir!
            Today on less than perfect conditions it did a 55.9 mph.
            I would assume on conditions as in the above video it would be closer to 60.
            I tried an X432B back cut (X632 currently) and the speed went wayyyy down 46.6 mph.
            • martin
              • 2887
              Yep the way i calc on an x632 i get 56.6mph.
              • Basstronics
                • Jun 2008
                • 2345
                Sweet. One day I need to learn these calculations!
                I would like to see if there is a sweeter prop out there... Hmmm
                The 1.6 pitch vs the 1.4 was evident... As soon as it went in the water I got a bit out I could tell it was way slower.
                • TheShaughnessy
                  • 1431
                  you just use the speed calculator on OSE. Unless you want to know the actual formula the calculator uses.
                  • martin
                    • 2887
                    You should be able to use a larger prop on the 3650 - 3900kv for more speed. I use that size prop x632 on a 15" mono with a little 3800kv 450 size outrunner ( 28mm can size ) on 3s 60c. Just check temps.
                    • Basstronics
                      • Jun 2008
                      • 2345
                      What would you guys suggest prop wise?
                      • Make-a-Wake
                        FE Rules!
                        • 5557
                        Yeah!!!! I'll take fresh baked chocolate chip.................I'll pm my addy to ya!!
                        • Make-a-Wake
                          FE Rules!
                          • 5557
                          What about this??????????
                          http://www.offshoreelectrics.com/pro...?prod=oct-1735
