Don't quite understand your question, but I use nothing but the flex shaft, adjust the motor mount until the flex goes into the stuffing tube without touching.
Use pretty much the same method when I'm installing a stuffing tube and motor mount. Tack it in with CA then glass and epoxy.
A drill, ruler, sharpie and a machinists square and vernier calipers, maybe some files are about the only tools I really use to build a 'glass hull boat.
The best "tool" I've seen to align the motor shaft and stuffing tube was posted by one of the members a while back. It was a coupler attached to the motor shaft with a length of drill it in the coupler to figure out where the stuffing tube should go. i think it was D.smock that posted it, if you want to search for it.
By coincidence I am gluing in a motor and shaft right now. The photo shows the 3/16" solid shaft in the coupler; the largest 9/32" OD brass tube will be glued into the hull. The 1/4" OD brass tubing is next with a 7/32" OD tube which is a slip fit for the 3/16" drive shaft. No slop, perfect alignment. I find that using flex cable can cause misalignment as the cable will bend slightly while gluding which leaves the alignment off.
Yep. Pretty much the best way IMO. I have several "adapter rods" made that range in size to do that same job. Just need to take some round stock and turn it on a lathe to work what ever stuffing tube size you plan on using. 3/16 and 1/4" alum rod turned to the right diameter. Makes for a perfect alignment.
[ATTACH=CONFIG]80258[/ATTACH]
Fluid, I do my hydros the exact same way as you. Monos are a different story. Especially the one Brian did in my Delta Force 33. This will take me a little while to figure out. The carbon fiber flood tube is epoxied sealed flush with tube end.
I would show the strut angle, trim tab and turn fin placement, but that is top secret. I wish he included the most important part...the prop and motor.
