Been checking out the water cooled in sponson motor mounts from fc i am running t600 size motors and have 6mm to. 187 couplers. Thing is i like running thrust bearings, does anyone know if thrust bearings will work or are needed? Thanks guys this is probably a question for ben at fc but wanted to see if anyone had experience with these mounts.
fc in sponson square motor mount thrust bearings?
Tags: None -
Without a thrust bearing, these helicopter motors take the full force of the prop shaft in a boat on that little circlip on the shaft. I've had one twist itself out of the groove & the whole can & armature moves back from the front plate. Only as far as the gap between the drive dog & the strut would allow, but it wasn't good. But the thrust bearing needs to rest against the motor mount, not the circlip.See the danger. THEN DO IT ANYWAY!!!
http://forums.offshoreelectrics.com/...hp?albumid=320 -
Ya i have broken a clip on one of my motors too. Im not sure if the fightercat mount allows for one to use a thrust bearing if anyone has used one let me knlw. ThanksComment
