Stuffing tube question
  • LOVE6S
    • May 2012
    • 545
    I am going to do my first scratch build, should I use a stuffing tube with a liner or one without?
  • ozzie-crawl
    • Sep 2008
    • 2865
    Thats one of those things that is personal choice. You will get pros and cons for both. I have never done a build with out using one.
    • siberianhusky
      • Dec 2009
      • 2187
      Some guys do some don't simple as that, I have never run a boat with one. Never had any problems so for me I won't change.
      IMO they add driveline drag.
      • LOVE6S
        • May 2012
        • 545
        So for a 3/16 flex without a liner I need a 1/4 or 6mm brass tube, is that correct guys, does water come up thru more if you dont use a liner?
        • bill34207
          • Dec 2009
          • 2553
          1/4" works well with 3/16" flex and no liner. You might want to add a short 7/32" piece on the motor end to help keep down water intrusion and keep the flex centered better. It can be soldered in or use a little loctite 603 to secure it. (solder holds up to heat better).
          I used to run with teflon liners but after having one snag the flex and start spinning inside the tube gave up on that idea.
          My YouTube Vids
          • LOVE6S
            • May 2012
            • 545
            Do yo solder it with the flex in to center or will it solder the flex too?
            • ozzie-crawl
              • Sep 2008
              • 2865
              I am only just getting back into FE after a 2 year break but thought 1/4 tube was used for 3/16 with a liner or .187 flex and no liner.
              3/16 and no liner needs the next size tube down.
              • LOVE6S
                • May 2012
                • 545
                I was looking on the OSE site and it said 1/4 for 3/16 shaft, I want to get the correct one.
                • LOVE6S
                  • May 2012
                  • 545
                  Do you use a liner or just a tube?
                  • Rumdog
                    • 6453
                    No liner. Just go by what OSE shop recommends. It is right on the money. Cat, mono, or hydro?
                    • martin
                      • 2887
                      Your talking .187" flex but also mentioning 3/16", they are both the same size diam. Getting confusing on what you mean, lets start again. 1/4" o/d tube takes a .187" flex with no liner, 9/32" o/d tube takes a .187" flex with a liner.
                      • LOVE6S
                        • May 2012
                        • 545
                        Its one of those sprintcat knockoffs on ebay, 30 inch cat, 125.00 shipped, its my first scratch build, I am excited, but I want it to come out good, do you think I should use one of those stuffing tube blocks to put in the tube or just put a slot in and fill around it?
                        • LOVE6S
                          • May 2012
                          • 545
                          Yes I said 3/16, but yes .187 flex is what I am going with, so the .250 or 1/4 OD tube is the one to get, is that correct?
                          • martin
                            • 2887
                            Yes .250" or 1/4" o/d if your not using a liner.
                            • martin
                              • 2887
