I want to do away with the 2 part flex in my pursuit but will this fit the stuffing tube as I don't want to start ripping the existing one out. Thanks
Upgrading Pursuit flex
Tags: None -
The problem is I've epoxied it all in to seal the leaks when I got the hull.Comment
I will give it a bash then. That kit looks like a good upgrade cos the stinger is the same as the stock one.Comment
The Prestwich models one is HF35 listed under flexshafts, this is a 3/16" stub with a .187" flex brazed together. Also speak to Tony at Model Marine Supplies, the last one of this size i got from him was a Speedmaster. Very good quality & well put to gether, the Speed master ones use a longer stub so is better to go between the 2 bushings & still have a decent amount to get the dog, prop & nut on. Some flexes can be a bit short on stub length. To give you an idea go into OSE store & they have these very shafts specifically for the Pursuit, the ones Tony has are around 21" long so just need cutting to length.Comment
Forgive me for being a bit stupid but I really struggle with the flex sizes bushing etc. are these a direct replacement for the 2 part flex as I thought it would be like the genesis and either need a new strut/stinger or have the old bushing drilled out to fit the one piece flex.Comment
Dosnt the Genesis use a smaller flex either a .150" or 4mm & a small stub, the Pursuit should come with a .187" square end flex with a 3/16" stub or at least the one i had did so it was just a case of fitting the new 1 piece .187" x 3/16" shaft.Comment
Yea the genesis shaft is smaller. I will give model marine supplys a ring. I need to order a prop anywayComment
I always use him for props. Fast service and he seems to be one of the cheapest.Comment
