Namba hull length specs?
  • keithbradley
    • 3663
    Is there a minimum hull length for classes? I can only find a maximum. I have a twin powered 36" cat that I am running on 8s 4000mah per motor and would like to enter it in S-offshore. That seems like the proper class as I am under the max voltage and under the 12,000mah capacity... or is there a minimum hull length?
    www.keithbradleyboats.com
  • Diegoboy
    • Mar 2007
    • 7244
    If it's like the IMPBA, there is a max length and no min unless stated
    • TheShaughnessy
      • 1431
      I dont think there is an s offshore. the s class is for saw competition only. You would want to do q offshore, no min length just a max of 40". You are over the p class length limit of 34" visit www.namaba.com for the rule book. You can find it under the resources tab at the top of the page.
      • keithbradley
        • 3663
        Sorry, I only want to participate in SAW competition. My Explorer wouldn't stand a chance in an oval race.
        • keithbradley
          • 3663
          This is the record I want to try for:
          S Offshore
          Boyd Marshall
          Oct-11
          2.721
          82.698
          NEV 1521
          Hydra & Marine Maritime
          Octura 442
          • TheShaughnessy
            • 1431
            Doesn't look like there is a hull minimum. Offshore is more a race format but i guess there is a saw class for it. You should be good to go.
            • keithbradley
              • 3663
              IMPBA says for Sport hydro
              ">40-50"
              I'm not sure if they are using the ">" properly there or not, but I guess it's a 40" minimum.
              For Mono/tunnel/hydro/OB tunnel it just says "up to 50")
              Would a catamaran compete in sport hydro or tunnel?
              • Diegoboy
                • Mar 2007
                • 7244
                Cats are tunnels and tunnels are OB tunnels.
                • keithbradley
                  • 3663
                  So I can haz both records?
                  Are there specific events that qualify to hold a record, or is any record set at a SAW event eligible?
                  • T.S.Davis
                    • 6220
                    Keith, when you get it figured out you could hit the trials in Flint.
                    Check with Chris Harris if there's any confusion at all.
                    Noisy person
                      IMPBA rules for sport hydros do indeed have both minimum and maximum lengths. Inboard catamarans are not O/B tunnels. Inboard catamarans compete in the Tunnel class, I held several SAW records in that class. There is a different class for O/B tunnels - "O/B Tunnel." Check out the IMPBA records listing:
                      http://www.impba.net/attachments/063...%202012(1).pdf
                      • keithbradley
                        • 3663
                        Yeah, I get it now Jay. What I meant by "both records" was impba and namba. Obviously I'm being a little cocky for fun, but it would be fun to try for it as well as meet some of the racers.
