Rated 14 volts or 12 cells (with bec) it says on web site, but on the actual esc it says 25 volts??? So if I use the onboard bec I am limited to 14 volts? If I run an external bec then I can run up to 25 volts. What happens if I run 4s with the bec? Fry the RX?
From the website:
From the website:
Voltage range | 6 to 14 Volts |
Turn on Voltage | 6 Volts |
BEC Cut off voltage | 5 volts |
Number of Nicad NIMH Cells | 6 to 14 Cells |
Continuous Current Rating | 75 Amps |
PWM rate | 3 KC |
BEC rating | 1 Amp at 5 Volts |
Length | 2 inches |
Width | 1 inch |
Height | 1/4 inch |
Weight | 40 grams |
Servo Connector | Universal |
Power Cables | 13 gage |
Power Connectors | Astro |
