Water inlet fitting location
  • Basstronics
    • Jun 2008
    • 2345
    Im in process of putting my Pursuit together.
    I see the factory built ones has the water inlet on the right side past the rudder. With my transom layout there is not much room there.
    I was thinking of putting it on the left side between the trim tab bolts.
    Is there any negative effects of doing this? ANyone have any other better suggestions?
  • stadiumyamaha
    • 1284
    I'd put it up higher than that. As high as possible.
    white geico w/2200kv 3674 leopard 53.5mph 4s2p, geico w/ 1800kv outrunner 52mph on 4s2p, genesis w/2200kv castle 53.8 on 4s2p, impulse 31 w/2200kv castle, stock p1 and ul-1
    • properchopper
      rcgoatbuild@snotmail.com
      • 6968
      Three things to be mindful of : entry into hull for most direct path to speedy while avoiding proximity to driveline, enough slack to allow full rudder travel AND not too much excess slack to allow tubing to be clipped by prop (happened to me during a race while doing a penalty lap- lost cooling & burned up a speedy)
      Two examples of dealing with it :
      • ron1950
        • 3024
        wow really like the red installation lol
        • properchopper
          • 6968
          Glad you like it; Took a little thinking, but I think I nailed it
          • LarrysDrifter
            Big Booty Daddy
            • May 2010
            • 3278
            Since you have a mono, id go with Tones way like he did on his white Insane mono. Run the lines the same way, going through the hole in the rudder bracket. I selfishly copied his exterior cooling method and it works great.
            • Basstronics
              • Jun 2008
              • 2345
              Thanks for the wisdom guys.
              Guess I will squeeze it in on the right side. I would run thru the rudder slot but my pushrod has a bend in that area and I dont want to risk it coming into contact with it.
              • LarrysDrifter
                Big Booty Daddy
                • May 2010
                • 3278
                My silcone rubs the pushrod with no problems at all. As long as the pushrod doesnt have any burrs on it, the silicone will be just fine.
                http://forums.offshoreelectrics.com/...0&d=1320029112
