Rum my genesis first time today leopard 4082 1250 kv two 3 s lipo 4000mah 30c with swordfish 200amp esc and a 640 propellor got 38 mph on this set up does that seem to be ok looking for advice only new to this boat thing also got the prop shaft upgrade fitted let me know
Genisis first run today
Did you run the batteries in series for 6s? Seems slow for 6s if so. That 4082 can spin ALOT of prop, but the hull is narrow so you will have to fight the torque roll. I'd throw an x645 on it, or an x447.NEED PARALLEL CONNECTORS?? QUALITY 5.5MM, 8MM, 8 AND 10 AWG, GET THEM HERE:http://forums.offshoreelectrics.com/...est!&highlight=
A "Y" connector is normally used for parallel setups.................. you sure its in series?NEED PARALLEL CONNECTORS?? QUALITY 5.5MM, 8MM, 8 AND 10 AWG, GET THEM HERE:http://forums.offshoreelectrics.com/...est!&highlight=
Y connector sounds like deans, is that right? If so, you should change to bullet connectors. Have you removed the motor to make sure the rotor is intact? Is that what you mean by rattling, or is it stuttering? Was it a lot of water?Disclaimer: I hereby accept the potential loss of motor, ESC, entire boat, or credit rating, and forfeit all expectations of success.Comment
Get a Turnigy 120a speedo for 49 bucks at Hobbyking.NEED PARALLEL CONNECTORS?? QUALITY 5.5MM, 8MM, 8 AND 10 AWG, GET THEM HERE:http://forums.offshoreelectrics.com/...est!&highlight=
