water where its not supposed to be
  • J.Calway
    • Jun 2012
    • 19
    well i greese up but still get water up through the shaft, a little only on first run but more on second run and so on... how often should i greese up and what sort of greese to use ? is there a after market seal i can put at the wet end of the shaft to limit water getting into the boat or is it mabe the type of greese i am using...?
  • Rumdog
    • 6453
    How do you know that is where the water is coming from?
    • J.Calway
      • Jun 2012
      • 19
      good point .... i have a line of water droplets accross the hatch from one side to the other above the shaft is the only evidence i can come up with. what greese should i be using ?
      • martin
        • 2887
        If the water is coming up through the tube (common problem even when greased), to stop this cut a piece of silicon water tube around 1/2" long & put it over the end of the stuffing tube so 1/4" of the tube over hangs the tube. this piece that over hangs forms a seal against the flex, just make sure the i/d of the silicon tube is not to tight on the flex.
        • J.Calway
          • Jun 2012
          • 19
          Thanks martin i will give that a go. what sort of greese should i be using ?
          • martin
            • 2887
            Allways make sure where the stuffing tube joins the strut its sealed as water enters their & is forced up the tube, water tends to go up easier if no teflon liner is used ( other benifits to not using a liner as well ). Everybody seems to have their preference on greases, personally i use Grimracer Speed Grease & sometimes if i want thinner stuf i use chainsaw bar oil ( for an oil its nice & sticky but much thinner than grease).
            • J.Calway
              • Jun 2012
              • 19
              how do i get a seal in the strut? i usually greese by slipping the rudder off then removing the strut to get at the drive shaft. is this the correct way. ? i figure this seal you talk of is the root of my water issue as the first run after greesing yeilds no water. the next run ,even with the silicone tube in place , i get water through the tube.. or is it that i have to greese after each run ?
              • J.Calway
                • Jun 2012
                • 19
                Well i finally got water into that speedy . now i have a nice black finish to the inside of my hull. it was a dodgy speedy anyhow from what i have read . now i can get a better one. : )
                • electric
                  • May 2008
                  • 1744
                  By the way, you can also put a piece of shring wrap where the copper tube meets the strut and shrink it around there. Sometimes water pushes through that seam at speed and then it pushes the water up the shaft. Dosen't hurt to do it.
                  • JIM MARCUM
                    • Jun 2011
                    • 773
                    FYI - I use lithium grease on my shafts. JIM
                    JIM MARCUM: NAMBA 777; EX? SoCal FE Racers Club; D-19; Official 2012 NAMBA FE Nationals Rescue Diver; Purple Heart Viet Nam Vet; Professional SCUBA/HOOKA Diver, KELCO, 1973-1978; BBA 1978, Magna Cum Laude; MBA 1980 w/honors; Retired DOD GS1102-12 Contract Specialist
                    • J.Calway
                      • Jun 2012
                      • 19
                      well i was looking at the swordfish 200a speedy.... anyone use this speedy before ? thanx Jim and thanx also Electric, thats a bonza idea as that is where the water was getting in.
