Clarification for the Leo 4092
  • runzwithsizorz
    • Jan 2009
    • 896
    It would seem that some esc's need to be programed with near pinpoint accuracy. Stevens' listing for the Leo 4092, 2080kv, states; 3.5D, AND 2.5D.
    Soooo, which is it?
  • carlcisneros
    • Jan 2010
    • 1218
    I just e=mailed Steven about that motor and also the 1480kv motor.
    should hear back from him in a day or so.
    either way, they are both listed as Delta winds.
    lets see what the proper numbers are.
    • Steven Vaccaro
      • 8721
      the 2080 is a 2.5d
      • runzwithsizorz
        • Jan 2009
        • 896
        Thank you Steven. Just dotting eyes, and crossing tees.
          • 9488
          what's the best timing * for the 2080kv ?
          thanks
            Two degrees.
              • 9488
              Originally posted by Fluid
              Two degrees.
              Ok that's because of the D wind correct?
              I've got my speedo set to 15* right now..
              things did get a little warm yesterday at the races..
              I'll bump it down
              thanks
              • martin
                • 2887
                10 - 15degrees are for y wind motors, d wind will run hotter at that timing.
                • Steven Vaccaro
                  • 8721
                  It would be near impossible to do this. In order for this to be accomplished a motor and esc would need to be tested and fine tuned together as a pair by a factory. I always start my testing with low timing. Then fine tune from there. Moving up in timing until the speed results are the same, but the motor is hotter than previously. Then move a bit back in timing from there.
                    • 9488
                    If I could stay on this just a min..
                    getting hotter with higher timing without more speed = wasted amps right?
                    both my motor and esc were right at 125* each runing 4s with a x645 prop in a DF33
