AQUACRAFT 60Amp ESC Repair/Modification
    This weekend I was running a Motley Crew 1800 Kv motor and 60A ESC in my Mean Machine when after a heat the boat stopped and would not come back in. Retrieved the boat and it checked out fine(?). Next heat it armed okay, but quit after the first lap. I checked the cap and yep, the end was bulged. I had run this ESC for several years so I wasn't too unhappy with this turn of events; fortunately the ESC wasn't toast - I knew the cure. I twisted off the old cap with pliers, cut off the wires close to the ESC and soldered on a new, slightly bigger cap - 4700 mF. Glued to the top of the ESC this cap solved the problem. It is larger than required, but I had a handful laying around for higher amperage controllers.
    Post #5 in the thread below explains what to do - it's been awhile since this has been discussed so new Motley Crew or UL-1 owners may not know about it.
    http://forums.offshoreelectrics.com/...ight=capacitor
  • detox
    • Jun 2008
    • 2318
    Did an overly aggressive prop cause this? Does the Mean Machine have more drag than Motley Crew (larger riding surface)?
    • Alexgar
      • Aug 2009
      • 3534
      The mm is pretty wide and my converted mm is a little heavy
        This had nothing to do with the hull. This was one of the original UL-1 60A ESCs which were known to have weak caps. AquaCraft even upgraded them (slightly) in subsequent versions. But really, this ESC had been run for 3 years - who could complain? Realize that most ESCs are an expendable item anyway, and that damage is often cumulative. This one had three-years-worth of abuse before it blew the cap, and $1.25 later it works fine again. I wish all ESC repairs were this easy....
        • ozzie-crawl
          • Sep 2008
          • 2865
          3 years and just a new cap to get it going again,got to be happy with that.
          I wish AQ and PB would make some bigger esc,s but exactly the same being potted or sealed in extruded alloy.
