I understand how a common .150 is made. The cable simply "glides" into the stub shaft which has a bore the size of .150, then is either soldered or epoxied with thread locker. The diameter of the shaft itself is bigger at 3/16" which is .187.
Now if the cable is .187, something has to give, do they grind down somewhat the cable for it to go into the stub shaft? I don't run this size but from photos I can see the cable is as thick as the sub shaft. Any enlightenment will be greatly appreciated!
